I was using rabbit in 12.04 LTS and then upgraded to 13.04 while rabbit menu was gone. So I went to the install page and followed the instructions:
  1. sudo add-apt-repository ppa:rabbitvcs/ppa
  2. sudo apt-get update
  3. sudo apt-get install rabbitvcs-nautilus3
  4. restart computer, no context menu. So I continued:
  5. sudo apt-get install rabbitvcs-gedit
  6. sudo apt-get install rabbitvcs-cli
    • Log out
    • log in
    • open nautilus,
    • right click on random folder
but still no "Rabbit VCS" in the context menu. I am certainly doing something incorrectly. But cannot figure out what...
EDIT Nautilus version is 3.6.3 and it si basically the default which comes with Ubuntu 13.04 - in Ubuntu it is called as "Files"
Contents of .config/rabbitvcs/RabbitVCS.log :
2013-06-18 10:02:45,462 ERROR   rabbitvcs.vcs.svn       The path '/home/janipav/workspace/MassFileSender' appears to be part of a Subversion 1.7 or greater
working copy.  Please upgrade your Subversion client to use this
working copy.
Traceback (most recent call last):
  File "/usr/lib/pymodules/python2.7/rabbitvcs/vcs/svn/__init__.py", line 254, in statuses
    update=update)
ClientError: The path '/home/janipav/workspace/MassFileSender' appears to be part of a Subversion 1.7 or greater
working copy.
2013-06-19 09:56:19,047 ERROR   rabbitvcs.vcs.svn       The path '/home/janipav/workspace/XmlChanger' appears to be part of a Subversion 1.7 or greater
working copy.
  File "/usr/lib/pymodules/python2.7/rabbitvcs/vcs/sv2013-06-18 10:02:45,462 ERROR   rabbitvcs.vcs.svn       The path '/home/janipav/workspace/MassFileSender' appears to be part of a Subversion 1.7 or greater
working copy.
    update=update)
working copy.
working copy.
    update=update)
ClientError: The path '/home/janipav/workspace/XmlChanger' appears to be part of a Subversion 1.7 or greater
working copy.
working copy.
    update=update)
working copy.
2013-06-19 09:56:19,437 ERROR   rabbitvcs.vcs.svn       The path '/home/janipav/workspace/MassFileSender' appears to be part of a Subversion 1.7 or greater
working copy.
    update=update)
working copy.
working copy.
    update=update)
working copy.
    update=update)
working copy.
working copy.
    update=update)
working copy.
working copy.
    update=update)
working copy.
working copy.
    update=update)
working copy.
Contents of /usr/share/rabbitvcs/configspec.ini
[general]
language = string(default="English")
enable_attributes = boolean(default=True)
enable_emblems = boolean(default=True)
enable_recursive = boolean(default=True)
show_debug = boolean(default=False)
show_unversioned_files = boolean(default=True)
[external]
diff_tool = string(default="/usr/bin/meld")
diff_tool_swap = boolean(default=False)
[cache]
number_repositories = integer(default=30)
number_messages = integer(default=30)
[logging]
type = option("None", "File", "Console", "Both", default="Both")
level = option("Debug", "Warning", "Info", "Error", "Critical", default="Error")
You can fix the missing context menu. I suggest removing the installed PPA version and the ppa (How do I remove a PPA added via command-line?), reinstall the version from Ubuntu and follow the instructions I derived from the bug reported: https://bugs.launchpad.net/ubuntu/+source/rabbitvcs/+bug/1093533.
You need to download the following file http://rabbitvcs.googlecode.com/svn/trunk/clients/nautilus-3.0/RabbitVCS.py
Copy it (using root/su/sudo) to:
/usr/share/nautilus-python/extensions/RabbitVCS.py
You may also need to create the following symlink:
sudo ln -s /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0 /usr/lib/libpython2.7.so.1.0
You will need to restart your session (log out and back in again) to see the changes.
NGRhodes
  • 9,680
So, it seems like you have .svn files belonging to your older version of rabbitvcs(probably 1.6). These need to be upgraded to 1.7, which is the version you have installed. To do this, execute the following on a terminal:
svn upgrade
You need to reboot for this to complete. To reboot: sudo reboot
jobin
  • 28,567
