I really want to upgrade but if I do I need to be able to downgrade. I also want to know the spec are right for my system info.
System Info Memory 2.0 GiB Processor Intel Pentium(R) 4 CPU 2.80GHz x 2 Graphics are Gallium 0.4 on AMD CEDAR OS type 32 bit Disk 90.1 GB
Joe Mack
The easiest way to revert an upgrade that didn't work out is by using Clonezilla to make an image of your disk or OS partition(s) before doing the upgrade; then you can restore the image to your disk or partition if and when you decide to do so. (Note that this works even if the disk has Windows on another partition, and it doesn't matter whether the partition(s) you're cloning are primary or logical. Note also that it isn't necessary to clone your swap partition.)
Archelon
  • 83
