I've been using Steam on Linux for quite a while now and never had any problems. Recently though, in the past few days, Steam seems not to start anymore- or at least, I can't see it running and I can't access any of my games. I tried reinstalling it, but to no avail.
If I try to run "steam" in terminal, this is what I get:
Running Steam on ubuntu 12.04 64-bit
STEAM_RUNTIME is enabled automatically
and then nothing happens.
If I try opening it with STEAM_RUNTIME=0 steam, I get:
STEAM_RUNTIME is disabled by the user
Error: You are missing the following 32-bit libraries, and Steam may not run:
libpangoft2-1.0.so.0
libpango-1.0.so.0
libgtk-x11-2.0.so.0
libgtk-x11-2.0.so.0
libgdk-x11-2.0.so.0
libpangocairo-1.0.so.0
libgdk_pixbuf-2.0.so.0
libcairo.so.2
libpango-1.0.so.0
libnss3.so
libnssutil3.so
libsmime3.so
libplc4.so
libnspr4.so
So I'm quite at a loss as to what has happened here. I haven't changed anything in my configuration, and I'm not even sure where to find such libraries.
What can I do, since a removal and a reinstall didn't work?
Small update: I tried opening Playonlinux (my WoW installation stopped working now too), and I received an error message that basically said I no longer had any 32bit libraries and that my games could not run properly. So now the question is- how do I get them back? :)
SECOND UPDATE: I tried reinstalling the ia32-libs, and this is the outcome:
sudo apt-get install ia32-libs
Reading package lists... Done
Building dependency tree
ia32-libs : Depends: ia32-libs-multiarch
So then I tried running sudo apt-get install ia32-libs-multiarch , and I got this:
ia32-libs-multiarch:i386 : Depends: gstreamer0.10-plugins-good:i386 but it is not going to be installed
Depends: gtk2-engines:i386 but it is not going to be installed
Depends: gtk2-engines-murrine:i386 but it is not going to be installed
Depends: gtk2-engines-pixbuf:i386 but it is not going to be installed
Depends: gtk2-engines-oxygen:i386 but it is not going to be installed
Depends: ibus-gtk:i386 but it is not going to be installed
Depends: libcanberra-gtk-module:i386 but it is not going to be installed
Depends: libgail-common:i386 but it is not going to be installed
Depends: libgtk2.0-0:i386 but it is not going to be installed
Depends: librsvg2-common:i386 but it is not going to be installed
I think it's pretty obvious at this point that my 32libs are either gone or no longer recognized, but I have no idea why.
