-1
I am installing under Windows 8 64-bit. Installed Oracle Virtualbox 4.2.18. Downloaded Ubuntu 12.04 LTS ISO. Created a new VM and tried to start from the ISO file to install Ubuntu to the VM. Process of downloading third party software packages and installation runs a few hours and then apparently everything has been installed. It asks for a reboot when I do that it crashes. Next time around it asks if Ubuntu should be reinstalled. I have gone through this process twice already with no success.
Please help if you have a solution.
Arvind
I Have managed to install Ubuntu 64 bit with oracle Virtual Box.
Steps to install this OS with VB:
1) place the .iso file on a pendrive or dvd.
2) install the OS from DVD or pendrive.
3) When the installation is ready and asks you to restart system, unplug pendrive(or remove dvd).
4) close the VM by clicking on the x icon and send a shutdown to the system.
5) open the new VM.
6) It states that there is an error in loading the VM.
7) Just click OK and the VM works perfectly.
Enjoy!!!
Possibly this issue is involved:
https://www.virtualbox.org/ticket/11004
I haven't tried this, it sounds very "hacky," but this user suggests that instead of rebooting at the end of setup he unmounts the setup .iso, powers down the VM guest and finally restarts it. It then finishes the reboot normally:
https://forums.virtualbox.org/viewtopic.php?f=6&t=52381#p245283
Phoeey
  • 521
I'll add my 2 cents. This could be caused by a VirtualBox as @Phoeey mentioned.
If you just want to use Ubuntu as guest OS instead of experiencing the installation process, you can download pre-installed Ubuntu Images.
Basically .box file gzipped tar files (OVF). You can download from any of the places above, and untar the .box file, then import using VirtualBox.
There are plenty of well built Ubuntu Vagrant Base images which are ready for use:
More information:
Example
For example if you wanna grab Ubuntu 12.04 Precise box from Ubuntu vagrant box repository:
$ wget -c -S http://cloud-images.ubuntu.com/vagrant/precise/current/precise-server-cloudimg-amd64-vagrant-disk1.box
$ file precise-server-cloudimg-amd64-vagrant-disk1.box
precise-server-cloudimg-amd64-vagrant-disk1.box: POSIX tar archive (GNU)
$ tar xvf precise-server-cloudimg-amd64-vagrant-disk1.box
box.ovf
Vagrantfile
box-disk1.vmdk
Import the OVF using GUI, see Importing and exporting virtual machines.
Terry Wang
  • 10,185
I had the same issue, every time it would reboot after setting the kdump vitualbox would crash. I got around it by rebooting in the bios before attempting to set the kdump. The vm worked fine afterward.
EricG
