where I can find option: “Run command as a login shell” in pantheon terminal ?
You can run pantheon terminal this command:
pantheon-terminal . ~/.bashrc
When I run pantheon-terminal without . ~/.bashrc rvm for ruby not work, but with this option all work fine. I setting this command on hot corner - very comfortably.
You can read information about bash on this case - its help me run pantheon-terminal correctly: What does “Run command as a login shell” do?
- 121
I installed gnome-terminal and solved this problem.
sudo apt-get install gnome-terminal
- 13,475
I was looking to change the Shell Pantheon Terminal uses, also. To enable me to use the Shell enhancements provided by the Trezor Agent (trezor_agent).
I found it can be updated in dconf, using the following command:
$ gsettings set org.pantheon.terminal.settings shell '/bin/bash'
It however, doesn't seem to 'like' (it just hangs) command flags etc (e.g. --login). So an alternative is to compose your own script and use this as your Shell:
(for bash)
#!/bin/sh
exec bash --login
(for zsh)
#!/bin/zsh
exec zsh --login
Save this file (I opted for /bin/tsh, but the name is unimportant), make it executable:
$ sudo chmod +x /bin/tsh
Then update Pantheon to use it as your Shell:
$ gsettings set org.pantheon.terminal.settings shell '/bin/tsh'
- 101
