After countless problems trying to program NASM Assembly in a 64-bit Ubuntu install in VirtualBox, I figured I'd just go to 32-bit programming for now.
I'm no expert - can I install 32-bit Ubuntu in VirtualBox, where the host is 64-bit?
Saturn
  • 223
Yes, you can install a 32-bit Ubuntu virtual system in a 64-bit host.
To do this, follow these steps:
  1. Install VirtualBox from the Ubuntu Software Center.
  2. Download the desired Ubuntu ISO file (32-bit in your case from the Ubuntu page).
  3. Create a new machine from the File → New menu.
  4. Make sure that you select the "Ubuntu" OS (instead of "Ubuntu (64-bit)").
  5. Setup your other options.
  6. Launch the virtual machine and install Ubuntu (select the downloaded ISO file when prompted for a CD or DVD media).
  7. After installing Ubuntu and "rebooting", install the VirtualBox drivers.
  8. Setup the new installation as desired.
I hope that this will help you solve your problem.
Edit: I found a video on YouTube that explains how to install Ubuntu on VirtualBox (in case that you did not use VirtualBox before).
