When I ran to Nvidia's website to download their 64bit Linux drivers, it downloaded a file named "NVIDIA-Linux-x86_64-319.49.run". Since this wasn't a file extension I'd seen before, I assumed double clicking would do nothing (Incorrect; it actually tried opening it in a word processor which hilariously meets with a crashed word processor).
I installed new drivers through a terminal. For future reference, however, assuming this is an archive, and clearly Nvidia expects everyone to be able to crack it open on command, how would I go about making the .run file actually be useful? Was there a command to decompress it and install the drivers? Was it a script and I just have no idea how to execute it?
(Very new to Linux; Ubuntu's my first attempt at running a distro since ...oh, RedHat 6.something. Anyways, so much for context.)
The way to do this is to simply make the .run file executable and run it.
chmod +x NVIDIA-Linux-x86_64-319.49.run
You need to kill the x-server first. Check this question for the way to kill the x server. First go to virtual terminal tty1 by pressing Ctrl+Alt+F1. Then run
sudo service lightdm stop
Later run this
sudo ./NVIDIA-Linux-x86_64-319.49.run
This will install the driver. To restart, run this command in the same F1 terminal
sudo service lightdm start
or just restart.
I have tried to install NVidia drivers and they made my system crash badly. Hence, I advice you to avoid NVidia and stick to Nouveau (as mentioned in the comments) unless you want to test your patience and Ubuntu's sturdiness.
VedVals
  • 3,651
