Off late I am receiving continuous system alerts regarding low disk space in my root directory. I am given to understand that all my system updates are being saved in my root directory instead of my home directory and I do not know how to change this!!
This is the output of my /boot:
/boot$ ll
total 73144
drwxr-xr-x 3 root root 4096 Sep 12 01:09 ./
drwxr-xr-x 25 root root 4096 Aug 3 03:19 ../
-rw-r--r-- 1 root root 848290 Jan 25 2013 abi-3.5.0-23-generic
-rw-r--r-- 1 root root 852420 Jun 20 14:46 abi-3.5.0-36-generic
-rw-r--r-- 1 root root 852910 Jul 10 14:09 abi-3.5.0-37-generic
-rw-r--r-- 1 root root 147880 Jan 25 2013 config-3.5.0-23-generic
-rw-r--r-- 1 root root 148142 Jun 20 14:46 config-3.5.0-36-generic
-rw-r--r-- 1 root root 148157 Jul 10 14:09 config-3.5.0-37-generic
drwxr-xr-x 3 root root 12288 Sep 12 01:07 grub/
-rw-r--r-- 1 root root 15540700 Jul 25 14:14 initrd.img-3.5.0-23-generic
-rw-r--r-- 1 root root 15626049 Jul 26 03:38 initrd.img-3.5.0-36-generic
-rw-r--r-- 1 root root 15688487 Sep 12 01:09 initrd.img-3.5.0-37-generic
-rw-r--r-- 1 root root 176764 Nov 27 2011 memtest86+.bin
-rw-r--r-- 1 root root 178944 Nov 27 2011 memtest86+_multiboot.bin
-rw------- 1 root root 3023265 Jan 25 2013 System.map-3.5.0-23-generic
-rw------- 1 root root 3021733 Jun 20 14:46 System.map-3.5.0-36-generic
-rw------- 1 root root 3022033 Jul 10 14:09 System.map-3.5.0-37-generic
-rw-r--r-- 1 root root 5189248 Jul 25 11:06 vmlinuz-3.5.0-23-generic
-rw------- 1 root root 5183904 Jun 20 14:46 vmlinuz-3.5.0-36-generic
-rw------- 1 root root 5184992 Jul 10 14:09 vmlinuz-3.5.0-37-generic
Will deleting any unused kernel files help? I am pretty confident that my current kernel version is 3.5.0-37-generic, so does that imply I can delete the other two: 0-23 and 0-36 ? which files should I be deleting here or none at all?
Also, are there any other things I should be doing in order to free up space on my root folder and make room for further system updates? Is there any way to change this location to somewhere in the "home" directory instead?? Thanks in advance !
Edit:
$ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/sda10 5.7G 5.2G 244M 96% /
udev 1.9G 4.0K 1.9G 1% /dev
tmpfs 766M 928K 766M 1% /run
none 5.0M 0 5.0M 0% /run/lock
none 1.9G 368K 1.9G 1% /run/shm
/dev/sda11 27G 16G 9.8G 61% /home
