Apt resulted few erronous lines on dist-upgrade.
Preparing to replace gir1.2-mutter-2.91 2.91.93-0ubuntu1~build1 (using .../gir1.2-mutter-2.91_3.0.0-0ubuntu1~build1_amd64.deb) ...
Unpacking replacement gir1.2-mutter-2.91 ...
dpkg: error processing /var/cache/apt/archives/gir1.2-mutter-2.91_3.0.0-0ubuntu1~build1_amd64.deb (--unpack):
 trying to overwrite '/usr/lib/mutter/Meta-3.0.typelib', which is also in package gir1.2-mutter-3.0 3.0.0-0ubuntu1~build2
NOTE. I have also installed gnome-shell, Other desktops (Unity, Classic) does not load and report error (Could not load ths session etc.) on login time. So Using gnome-shell.
Shoaib Nawaz
  • 2,389
Looks like the same file exists in two distinct packages: gir1.2-mutter-3.0 and gir1.2-mutter-2.91 (note these are package names without version numbers). You could:
  1. Remove one of the packages, probably gir1.2-mutter-3.0. The downside is that this could force you to remove other packages that depend on it.
  2. Install gir1.2-mutter-2.91 using dpkg --force-overwrite, which will overwrite the conflicting file. There is a small risk that this could cause problems, but you can always recover by reinstalling the old version.
Adam Byrtek
  • 9,861
Please make sure that there's a bug filed about this.
Colin Watson
  • 6,400
