78
How do I convert epub to mobi using Calibre for this?
6 Answers6
136
Yes, Calibre package contains a script called ebook-convert to convert ebooks between formats. You can install Calibre with
sudo apt-get install calibre
then
ebook-convert "book.epub" "book.mobi"
NB: Other formats are supported, too:
ebook-convert "book.azw3" "book.pdf"
muru
  • 207,228
19
I found a script for batch conversion:
for book in *.epub; do echo "Converting $book"; ebook-convert "$book" "$(basename "$book" .epub).mobi"; done
It works good for me, but the process is pretty slow.
Install calibre. Works with any arbitrary folder depth.
find . -name '*.epub' -type f -exec bash -c 'ebook-convert "$0" "${0%.epub}.mobi" --prefer-author-sort --output-profile=kindle --linearize-tables --smarten-punctuation --enable-heuristics' {} \;
As of November 2021. I had to run the command using sudo.
E.g
sudo ebook-convert book.epub book.mobi
I didn't need the quotes, but you can use them if your file name has spaces. E.g:
sudo ebook-convert "book one.epub" "book one.mobi"
Everything else works as described in the accepted answer above.
Ai Xing
  • 31
You can also do this without installing Calibre. This would be really handy on a Chromebook, for example. There is a free, online site called EPUB Converter that will let you upload the epub and it lets you then download the mobi equivalent.
redbmk
  • 213
Yes, you can use Calibre for epub to mobi conversion. They declare mobi as supported output format in their FAQ.
I don’t think there’s anything Ubuntu-specific in the question, so it would probably belong somewhere else.
