I am using Ubuntu 12.04 amd64 desktop.
It worked fine, but after the last update, the system does not shutdown.
It gets stuck with the last line on the screen being:
unmounted /kernel/debug
I have to use Ctrl+Alt+Del. It restarts the machine. Then at the grub screen, I choose to hard shutdown the machine.
Can anybody help me with this?
Alaa Ali
  • 32,213
noob00
Well after some searching I came to know that , your problem belongs to Kernel.All you need to is simply update your Kernel, Source .
So you have to update your Kernel to 3.9, and Instructions are
Open your terminal and then paste this command to make sure that your system is up to date.
sudo apt-get update && sudo apt-get dist-upgrade && sudo apt-get autoremove
Then
after doing update , restart your system to apply the changes and then change to tmp directory.
cd /tmp
Then for 32-bit Ubuntu Kernel is
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.9-rc8-raring/linux-headers-3.9.0-030900rc8-generic_3.9.0-030900rc8.201304211835_i386.deb http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.9-rc8-raring/linux-headers-3.9.0-030900rc8_3.9.0-030900rc8.201304211835_all.deb http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.9-rc8-raring/linux-image-3.9.0-030900rc8-generic_3.9.0-030900rc8.201304211835_i386.deb
for 64-bit
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.9-rc8-raring/linux-headers-3.9.0-030900rc8-generic_3.9.0-030900rc8.201304211835_amd64.deb http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.9-rc8-raring/linux-headers-3.9.0-030900rc8_3.9.0-030900rc8.201304211835_all.deb http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.9-rc8-raring/linux-image-3.9.0-030900rc8-generic_3.9.0-030900rc8.201304211835_amd64.deb
Then install it with
sudo dpkg -i *.deb
Then update your GRUB
sudo update-grub2
Now restart your system to apply the changes.
Source
Hope that helps.
Raja G
  • 105,327
  • 107
  • 262
  • 331
I've found these solutions for solving the problems with "improper shutdown" and "missing battery indicator" as follows:
System: lenovo G400
OS: Ubuntu 12.04 LTS
Solution: booting with the pci=noacpi kernel parameter (https://wiki.ubuntu.com/DebuggingACPI)
To temporarily add `pci=noacpi' parameter to a kernel:
  1. start your system press and hold Shift key
  2. highlight the kernel you want, and press e key
  3. to the line starting with linux add pci=noacpi at the end
  4. press Ctrl+x to boot
To make change permanent:
  1. sudo gedit /etc/default/grub
  2. have this line GRUB_CMDLINE_LINUX_DEFAULT="pci=noacpi"
  3. sudo update-grub then reboot
BuZZ-dEE
  • 14,533
have you tried shutting down from terminal using the command
sudo shutdown -P now
sosytee
  • 2,738
