So I installed Ubuntu (full version, not live) onto my 8gb USB flash drive. When I start up my PC though and go through the boot options the flash drive doesn't show up as one. I'm not really sure where to go from here. Any help/suggestions would be appreciated.
CamHart
  • 161
(1) Make sure that USB stick is inserted before entering BIOS. And consider that some computers list the USB drives under harddisk, so that one should change harddisk boot priorities to enable boot from USB.
(2) How do you install Ubuntu on the USB flash? And consider that the flash will work only on the computer from which you installed Ubuntu on it.
AliNajafies
  • 5,974
1) Prior to creating your flash drive installation, confirm that the hashes match on the ISO you downloaded.
2) Choose "something else" from the installer menu
3) Install normally insuring that you are targeting the flash drive.
4) Choose the flash device for the GRUB boot record installation.
I've followed this approach many times with Ubuntu, Lubuntu, Xubuntu, and Mate.
If for some reason your new flash system doesn't boot, double check the hash for the ISO and replace it if the hash doesn't match and start over. If the hash matches, try to repair or reinstall grub.
Source: Experience
Elder Geek
  • 36,752
