I have a fresh installed ubuntu 13.04 and trying to run two virtual maschines on it. It runs for a while and then it gets stuck host and guest (dont respond to ping or ssh). But it doesnt restart. i have to reboot the maschine. syslog doesnt show any sign of error. I could use some help to track down why it is and how to get rid of it. Thanks
<CPU count="4" hotplug="false">
<HardwareVirtEx enabled="true" exclusive="true"/>
<HardwareVirtExNestedPaging enabled="true"/>
<HardwareVirtExVPID enabled="true"/>
<PAE enabled="true"/>
<HardwareVirtExLargePages enabled="false"/>
<HardwareVirtForce enabled="false"/>
</CPU>
<Memory RAMSize="8000" PageFusion="false"/>
<HID Pointing="PS2Mouse" Keyboard="PS2Keyboard"/>
<HPET enabled="false"/>
<Chipset type="PIIX3"/>
<StorageController name="IDE" type="PIIX4" PortCount="2" useHostIOCache="true" Bootable="true"/>
<StorageController name="SATA" type="AHCI" PortCount="30" useHostIOCache="false" Bootable="true" IDE0MasterEmulationPort="0" IDE0SlaveEmulationPort="1" IDE1MasterEmulationPort="2" IDE1SlaveEmulationPort="3">
Edit: It also have the same behavior with vmware player.
alknows
  • 151
As it may be needed for some virtual machines to perform at the ultimate maximum, and modern CPU's do have an intelligent use of virtualization technology indeed, but for optimum stability of the host we need to leave it at least some resources.
Give the host a CPU
  • Leave at least 1 core running for the host (i.e. maximum 3 cores for the VMs on a quad-core system).
or
  • If we do have to assign all cores to the VMs we need to define an execution cap to leave some reserves for the host.
Spend some RAM to the host
Virtual Box Manager gives you a warning as soon as you assign more than 50% of available RAM to a VM. It may however be safe to
  • leave at least 512 MB (better more) of RAM for the host to avoid excessive swapping. Take virtual graphics RAM in account too.
This may considerably increase stability of the host OS. In case we run more than one VM in parallel we may have to further reduce the resources assigned to each as then the CPU cores and the RAM reserved for the VMs sum up.
Update
After a fresh installation it may also be a good idea to perform a software and kernel upgrade (sudo apt-get update && sudo apt-get dist-upgrade) for bugfixes, and for the same reason get the newest release of our virtualization software.
Takkat
  • 144,580
2 Days without jamming. I think we've got a winner. The VirtualBox Extension Pack might be the cause. i just removed it and disabled USB controllers in the vms configuration. So far no jamming. before it used to get stuck every hour.
Tested with:
Host: Ubuntu 13.04 and 12.04 (same behavior with both)
Guest: Ubuntu 12.10 and Win2012
CPU: i7-Core 4770
RAM 32GB
alknows
  • 151
I got this error and tried different solutions found all over the web. But the one worked for me is, reinstalling my Ubuntu OS with allocating the swap space as per the answer here, https://askubuntu.com/a/49138/81288 and after this I'm really got this issue fixed.
Also I'm attaching my VM configuration which is working very smoothly.
As a tail note, swap space is also needed if you would like to enable "Hibernate" option for your Ubuntu machine.
Stranger
  • 271
