After installing Ubuntu 12.04.3 LTS, the Windows 7 partition and an extra backup partition are no longer mounting automatically as they used to do in 10.04.2 LTS.
I have an ATA HardDisk.
What could be the problem? Any insights will be highly appreciated.
troylatroy
  • 1,275
You have to enter your partition information to /etc/fstab file. Then your disk will be mounted automatically!
Just go for following step:
  • First take back up of /etc/fstab
    sudo cp /etc/fstab /etc/fstab.backup
  • Execute following command to get your partition UUID information that will help you to configure /etc/fstab file.
    sudo blkid
    Search for your partition's UUID which you want to mount automaticall. Your HDD partitions shouls be displayed like:
    /dev/sda1: LABEL="Backup" UUID="00A0CE7EA0CE7A24" TYPE="ntfs"
    /dev/sda5: LABEL="40GBTWO" UUID="00A0CE7EA0CE7A24" TYPE="ntfs"
    /dev/sda6: UUID="7550252c-3da7-4cd9-8da3-71e9ba38e74a" TYPE="ext4"
    /dev/sda7: UUID="088fd084-a011-4896-aa93-c0caaad60620" TYPE="swap"
    /dev/sdb1: LABEL="SaurK" UUID="0DB6254A58CEF6F7" TYPE="ntfs"
    and so on. It is just an example but format will be same.
  • Now copy the UUID of the partitions which you want to insert in /etc/fstab file.
  • Now open /etc/fstab file and insert entry for your HDD partitions on the last line of /etc/fstab file. Take help from previous entry, for format etc:
    sudo gedit /etc/fstab
    When opened your entry would be like this:
    UUID=<your_UUID_for_Disk_partitions> /media/<location_where_you_want_to_mount>             ntfs    errors=remount-ro 0
    Just an example:
    UUID=00A0CE7EA0CE7A24 /media/Backup               ntfs    errors=remount-ro 0
    you may have to replace ntfs to ext4 or fat32 according to the file system of your partition. It displays in blkid output.
  • Now create location where to mount your disk partitions. Create a folder for each partitions to mount. ((note: a directory may be already created, if so ignore this step.) For example:
    sudo mkdir /media/Backup
  • Then execute this command once finished:
    sudo mount -a
You can refer this link for further help: Auto mounting with /etc/fstab Hope it works for you..
Saurav Kumar
  • 15,174
