45
Please explain what does following command mean:
awk -F: '{print $4}'
Alaa Ali
  • 32,213
PHP Learner
  • 2,948
  • awk - this is the interpreter for the AWK Programming Language. The AWK language is useful for manipulation of data files, text retrieval and processing
  • -F <value> - tells awk what field separator to use. In your case, -F: means that the separator is : (colon).
  • '{print $4}' means print the fourth field (the fields being separated by :).
Example:
Let's say that there's a file called test, and it contains the following:
Hello:my:name:is:Alaa
If we execute the command awk -F: '{print $4}' test, the output will be:
is
Because is is the fourth field.
      field1   field3  field5
           field2  field4
Alaa Ali
  • 32,213
  • You set the field separator with ...
    -F
    so that is ":" in this example.
  • You print the text that is between the 3th and 4th separator with ...
    '{print $4}'
  • And this explains it better:
    echo "154:266:377:454:533" | awk -F: '{print $4}'
    454
Rinzwind
  • 309,379
