This is a problem in 13.04 and it's a problem with the wifi. Ubuntu will never connect to the network. All of my other devices work fine.
The computer detects the network and pops up the wifi password dialog. I enter the correct password, click ok and it tries to connect for a few seconds and then asks for the password again. I am using a new D-Link Wireless N 150 Pico USB adapter which works fine under windows to connect to the same network.
I searched Google for a few hours and didn't find an answer, maybe someone here could help?
syslog contains:
Sep 7 09:25:40 mike-ubuntu NetworkManager[986]: get_secret_flags: assertion `is_secret_prop (setting, secret_name, error)' failed
Sep 7 09:25:40 mike-ubuntu NetworkManager[986]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) scheduled...
Sep 7 09:25:40 mike-ubuntu NetworkManager[986]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) started...
Sep 7 09:25:40 mike-ubuntu NetworkManager[986]: <info> (wlan0): device state change: need-auth -> prepare (reason 'none') [60 40 0]
Sep 7 09:25:40 mike-ubuntu NetworkManager[986]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) scheduled...
Sep 7 09:25:40 mike-ubuntu NetworkManager[986]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) complete.
Sep 7 09:25:40 mike-ubuntu NetworkManager[986]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) starting...
Sep 7 09:25:40 mike-ubuntu NetworkManager[986]: <info> (wlan0): device state change: prepare -> config (reason 'none') [40 50 0]
Sep 7 09:25:40 mike-ubuntu NetworkManager[986]: <info> Activation (wlan0/wireless): connection 'Wi-Fi connection 1' has security, and secrets exist. No new secrets needed.
Sep 7 09:25:40 mike-ubuntu NetworkManager[986]: <info> Config: added 'ssid' value 'kaylag2'
Sep 7 09:25:40 mike-ubuntu NetworkManager[986]: <info> Config: added 'scan_ssid' value '1'
Sep 7 09:25:40 mike-ubuntu NetworkManager[986]: <info> Config: added 'key_mgmt' value 'WPA-PSK'
Sep 7 09:25:40 mike-ubuntu NetworkManager[986]: <info> Config: added 'psk' value '<omitted>'
Sep 7 09:25:40 mike-ubuntu NetworkManager[986]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) complete.
Sep 7 09:25:40 mike-ubuntu NetworkManager[986]: <info> Config: set interface ap_scan to 1
Sep 7 09:25:40 mike-ubuntu NetworkManager[986]: <info> (wlan0): supplicant interface state: inactive -> scanning
Sep 7 09:25:41 mike-ubuntu wpa_supplicant[1017]: wlan0: SME: Trying to authenticate with 00:13:10:e1:f9:a2 (SSID='kaylag2' freq=2437 MHz)
Sep 7 09:25:41 mike-ubuntu kernel: [ 1277.665268] wlan0: authenticate with 00:13:10:e1:f9:a2
Sep 7 09:25:41 mike-ubuntu NetworkManager[986]: <info> (wlan0): supplicant interface state: scanning -> authenticating
Sep 7 09:25:41 mike-ubuntu kernel: [ 1277.681287] wlan0: send auth to 00:13:10:e1:f9:a2 (try 1/3)
Sep 7 09:25:41 mike-ubuntu wpa_supplicant[1017]: wlan0: Trying to associate with 00:13:10:e1:f9:a2 (SSID='kaylag2' freq=2437 MHz)
Sep 7 09:25:41 mike-ubuntu kernel: [ 1277.686768] wlan0: authenticated
Sep 7 09:25:41 mike-ubuntu kernel: [ 1277.687005] rtl8192cu 1-1:1.0 wlan0: disabling HT/VHT due to WEP/TKIP use
Sep 7 09:25:41 mike-ubuntu kernel: [ 1277.687010] rtl8192cu 1-1:1.0 wlan0: disabling HT as WMM/QoS is not supported by the AP
Sep 7 09:25:41 mike-ubuntu kernel: [ 1277.687014] rtl8192cu 1-1:1.0 wlan0: disabling VHT as WMM/QoS is not supported by the AP
Sep 7 09:25:41 mike-ubuntu kernel: [ 1277.688037] wlan0: associate with 00:13:10:e1:f9:a2 (try 1/3)
Sep 7 09:25:41 mike-ubuntu wpa_supplicant[1017]: wlan0: Associated with 00:13:10:e1:f9:a2
Sep 7 09:25:41 mike-ubuntu NetworkManager[986]: <info> (wlan0): supplicant interface state: authenticating -> associated
Sep 7 09:25:41 mike-ubuntu kernel: [ 1277.691496] wlan0: RX AssocResp from 00:13:10:e1:f9:a2 (capab=0x431 status=0 aid=12)
Sep 7 09:25:41 mike-ubuntu kernel: [ 1277.691541] wlan0: associated
Sep 7 09:25:41 mike-ubuntu NetworkManager[986]: <info> (wlan0): supplicant interface state: associated -> 4-way handshake
Sep 7 09:25:51 mike-ubuntu wpa_supplicant[1017]: wlan0: Authentication with 00:13:10:e1:f9:a2 timed out.
Sep 7 09:25:51 mike-ubuntu kernel: [ 1287.695734] wlan0: disassociating from 00:13:10:e1:f9:a2 by local choice (reason=3)
Sep 7 09:25:51 mike-ubuntu wpa_supplicant[1017]: wlan0: CTRL-EVENT-DISCONNECTED bssid=00:00:00:00:00:00 reason=3
Sep 7 09:25:51 mike-ubuntu NetworkManager[986]: <info> (wlan0): supplicant interface state: 4-way handshake -> disconnected
Sep 7 09:25:51 mike-ubuntu NetworkManager[986]: <info> Activation (wlan0/wireless): disconnected during association, asking for new key.
Sep 7 09:25:51 mike-ubuntu NetworkManager[986]: <info> (wlan0): device state change: config -> need-auth (reason 'supplicant-disconnect') [50 60 8]
Sep 7 09:25:51 mike-ubuntu kernel: [ 1287.711433] wlan0: deauthenticating from 00:13:10:e1:f9:a2 by local choice (reason=3)
Sep 7 09:25:51 mike-ubuntu kernel: [ 1287.712868] cfg80211: Calling CRDA to update world regulatory domain
Sep 7 09:25:51 mike-ubuntu kernel: [ 1287.783416] cfg80211: World regulatory domain updated:
Sep 7 09:25:51 mike-ubuntu kernel: [ 1287.783432] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Sep 7 09:25:51 mike-ubuntu kernel: [ 1287.783439] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Sep 7 09:25:51 mike-ubuntu kernel: [ 1287.783445] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
Sep 7 09:25:51 mike-ubuntu kernel: [ 1287.783450] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
Sep 7 09:25:51 mike-ubuntu kernel: [ 1287.783456] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Sep 7 09:25:51 mike-ubuntu kernel: [ 1287.783461] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Sep 7 09:25:52 mike-ubuntu NetworkManager[986]: <info> (wlan0): supplicant interface state: disconnected -> inactive
Sep 7 09:26:12 mike-ubuntu kernel: [ 1308.420423] sd 6:0:0:0: [sdb] Test WP failed, assume Write Enabled
Sep 7 09:26:12 mike-ubuntu kernel: [ 1308.422269] sd 6:0:0:0: [sdb] Asking for cache data failed
Sep 7 09:26:12 mike-ubuntu kernel: [ 1308.422282] sd 6:0:0:0: [sdb] Assuming drive cache: write through
I tried to disable WPA on the router and it still doesn't connect, I'm just trying to narrow down the issue.
sudo lshw -C network
*-network
description: Wireless interface physical id: 1 bus info: usb@1:1 logical name: wlan0 serial: 14:d6:4d:a7:0d:2e capabilities: ethernet physical wireless configuration: broadcast=yes driver=rtl8192cu driverversion=3.8.0-19-generic firmware=N/A link=no multicast=yes wireless=IEEE 802.11bgn
syslog after this: sudo iw wlan0 set power_save off
Sep 7 11:59:52 mike-ubuntu NetworkManager[969]: <info> Activation (wlan0) starting connection 'Wi-Fi connection 1'
Sep 7 11:59:52 mike-ubuntu NetworkManager[969]: <info> (wlan0): device state change: disconnected -> prepare (reason 'none') [30 40 0]
Sep 7 11:59:52 mike-ubuntu NetworkManager[969]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) scheduled...
Sep 7 11:59:52 mike-ubuntu NetworkManager[969]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) started...
Sep 7 11:59:52 mike-ubuntu NetworkManager[969]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) scheduled...
Sep 7 11:59:52 mike-ubuntu NetworkManager[969]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) complete.
Sep 7 11:59:52 mike-ubuntu NetworkManager[969]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) starting...
Sep 7 11:59:52 mike-ubuntu NetworkManager[969]: <info> (wlan0): device state change: prepare -> config (reason 'none') [40 50 0]
Sep 7 11:59:52 mike-ubuntu NetworkManager[969]: <info> Activation (wlan0/wireless): access point 'Wi-Fi connection 1' has security, but secrets are required.
Sep 7 11:59:52 mike-ubuntu NetworkManager[969]: <info> (wlan0): device state change: config -> need-auth (reason 'none') [50 60 0]
Sep 7 11:59:52 mike-ubuntu NetworkManager[969]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) complete.
Sep 7 11:59:52 mike-ubuntu NetworkManager[969]: <info> (wlan0): device state change: need-auth -> prepare (reason 'none') [60 40 0]
Sep 7 11:59:52 mike-ubuntu NetworkManager[969]: <info> Activation (wlan0/wireless): connection 'Wi-Fi connection 1' has security, and secrets exist. No new secrets needed.
Sep 7 11:59:52 mike-ubuntu NetworkManager[969]: <info> Config: added 'ssid' value 'kaylag2'
Sep 7 11:59:52 mike-ubuntu NetworkManager[969]: <info> Config: added 'scan_ssid' value '1'
Sep 7 11:59:52 mike-ubuntu NetworkManager[969]: <info> Config: added 'key_mgmt' value 'WPA-PSK'
Sep 7 11:59:52 mike-ubuntu NetworkManager[969]: <info> Config: added 'psk' value '<omitted>'
Sep 7 11:59:52 mike-ubuntu NetworkManager[969]: <info> Config: set interface ap_scan to 1
Sep 7 11:59:52 mike-ubuntu NetworkManager[969]: <info> (wlan0): supplicant interface state: inactive -> scanning
Sep 7 11:59:53 mike-ubuntu wpa_supplicant[1193]: wlan0: SME: Trying to authenticate with 00:13:10:e1:f9:a2 (SSID='kaylag2' freq=2437 MHz)
Sep 7 11:59:53 mike-ubuntu kernel: [ 1331.829097] wlan0: authenticate with 00:13:10:e1:f9:a2
Sep 7 11:59:53 mike-ubuntu NetworkManager[969]: <info> (wlan0): supplicant interface state: scanning -> authenticating
Sep 7 11:59:53 mike-ubuntu kernel: [ 1331.844435] wlan0: send auth to 00:13:10:e1:f9:a2 (try 1/3)
Sep 7 11:59:53 mike-ubuntu kernel: [ 1332.048053] wlan0: send auth to 00:13:10:e1:f9:a2 (try 2/3)
Sep 7 11:59:53 mike-ubuntu kernel: [ 1332.051835] wlan0: authenticated
Sep 7 11:59:53 mike-ubuntu kernel: [ 1332.052717] rtl8192cu 1-1:1.0 wlan0: disabling HT/VHT due to WEP/TKIP use
Sep 7 11:59:53 mike-ubuntu kernel: [ 1332.052779] rtl8192cu 1-1:1.0 wlan0: disabling HT as WMM/QoS is not supported by the AP
Sep 7 11:59:53 mike-ubuntu kernel: [ 1332.052786] rtl8192cu 1-1:1.0 wlan0: disabling VHT as WMM/QoS is not supported by the AP
Sep 7 11:59:53 mike-ubuntu wpa_supplicant[1193]: wlan0: Trying to associate with 00:13:10:e1:f9:a2 (SSID='kaylag2' freq=2437 MHz)
Sep 7 11:59:53 mike-ubuntu kernel: [ 1332.056098] wlan0: associate with 00:13:10:e1:f9:a2 (try 1/3)
Sep 7 11:59:53 mike-ubuntu NetworkManager[969]: <info> (wlan0): supplicant interface state: authenticating -> associating
Sep 7 11:59:53 mike-ubuntu wpa_supplicant[1193]: wlan0: Associated with 00:13:10:e1:f9:a2
Sep 7 11:59:53 mike-ubuntu kernel: [ 1332.089970] wlan0: RX AssocResp from 00:13:10:e1:f9:a2 (capab=0x431 status=0 aid=12)
Sep 7 11:59:53 mike-ubuntu kernel: [ 1332.090161] wlan0: associated
Sep 7 11:59:53 mike-ubuntu NetworkManager[969]: <info> (wlan0): supplicant interface state: associating -> 4-way handshake
Sep 7 12:00:03 mike-ubuntu wpa_supplicant[1193]: wlan0: Authentication with 00:13:10:e1:f9:a2 timed out.
Sep 7 12:00:03 mike-ubuntu kernel: [ 1342.094561] wlan0: disassociating from 00:13:10:e1:f9:a2 by local choice (reason=3)
Sep 7 12:00:03 mike-ubuntu wpa_supplicant[1193]: wlan0: CTRL-EVENT-DISCONNECTED bssid=00:00:00:00:00:00 reason=3
Sep 7 12:00:03 mike-ubuntu NetworkManager[969]: <info> (wlan0): supplicant interface state: 4-way handshake -> disconnected
Sep 7 12:00:03 mike-ubuntu NetworkManager[969]: <info> Activation (wlan0/wireless): disconnected during association, asking for new key.
Sep 7 12:00:03 mike-ubuntu NetworkManager[969]: <info> (wlan0): device state change: config -> need-auth (reason 'supplicant-disconnect') [50 60 8]
Sep 7 12:00:03 mike-ubuntu kernel: [ 1342.106375] wlan0: deauthenticating from 00:13:10:e1:f9:a2 by local choice (reason=3)
Sep 7 12:00:03 mike-ubuntu kernel: [ 1342.112407] cfg80211: Calling CRDA to update world regulatory domain
Sep 7 12:00:03 mike-ubuntu kernel: [ 1342.164006] cfg80211: World regulatory domain updated:
Sep 7 12:00:03 mike-ubuntu kernel: [ 1342.164102] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Sep 7 12:00:03 mike-ubuntu kernel: [ 1342.164109] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Sep 7 12:00:03 mike-ubuntu kernel: [ 1342.164116] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
Sep 7 12:00:03 mike-ubuntu kernel: [ 1342.164121] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
Sep 7 12:00:03 mike-ubuntu kernel: [ 1342.164127] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Sep 7 12:00:03 mike-ubuntu kernel: [ 1342.164132] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
ok, to try to narrow down the issue I thought it might be that the signal might be too weak so I moved the access point closer, I also disabled the security and tried to connect again and still no luck. I'm not sure if there is anything that stands out in here:
Sep 7 12:27:36 mike-ubuntu NetworkManager[868]: <info> Activation (wlan0) starting connection 'kaylag2'
Sep 7 12:27:36 mike-ubuntu NetworkManager[868]: <info> (wlan0): device state change: disconnected -> prepare (reason 'none') [30 40 0]
Sep 7 12:27:36 mike-ubuntu NetworkManager[868]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) scheduled...
Sep 7 12:27:36 mike-ubuntu NetworkManager[868]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) started...
Sep 7 12:27:36 mike-ubuntu NetworkManager[868]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) scheduled...
Sep 7 12:27:36 mike-ubuntu NetworkManager[868]: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) complete.
Sep 7 12:27:36 mike-ubuntu NetworkManager[868]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) starting...
Sep 7 12:27:36 mike-ubuntu NetworkManager[868]: <info> (wlan0): device state change: prepare -> config (reason 'none') [40 50 0]
Sep 7 12:27:36 mike-ubuntu NetworkManager[868]: <info> Activation (wlan0/wireless): connection 'kaylag2' requires no security. No secrets needed.
Sep 7 12:27:36 mike-ubuntu NetworkManager[868]: <info> Config: added 'ssid' value 'kaylag2'
Sep 7 12:27:36 mike-ubuntu NetworkManager[868]: <info> Config: added 'scan_ssid' value '1'
Sep 7 12:27:36 mike-ubuntu NetworkManager[868]: <info> Config: added 'key_mgmt' value 'NONE'
Sep 7 12:27:36 mike-ubuntu NetworkManager[868]: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) complete.
Sep 7 12:27:36 mike-ubuntu NetworkManager[868]: <info> Config: set interface ap_scan to 1
Sep 7 12:27:36 mike-ubuntu NetworkManager[868]: <info> (wlan0): supplicant interface state: inactive -> scanning
Sep 7 12:27:37 mike-ubuntu wpa_supplicant[906]: wlan0: SME: Trying to authenticate with 00:13:10:e1:f9:a2 (SSID='kaylag2' freq=2437 MHz)
Sep 7 12:27:37 mike-ubuntu kernel: [ 115.581772] wlan0: authenticate with 00:13:10:e1:f9:a2
Sep 7 12:27:37 mike-ubuntu NetworkManager[868]: <info> (wlan0): supplicant interface state: scanning -> authenticating
Sep 7 12:27:37 mike-ubuntu kernel: [ 115.620391] wlan0: send auth to 00:13:10:e1:f9:a2 (try 1/3)
Sep 7 12:27:37 mike-ubuntu wpa_supplicant[906]: wlan0: Trying to associate with 00:13:10:e1:f9:a2 (SSID='kaylag2' freq=2437 MHz)
Sep 7 12:27:37 mike-ubuntu kernel: [ 115.630642] wlan0: authenticated
Sep 7 12:27:37 mike-ubuntu kernel: [ 115.631154] rtl8192cu 1-1:1.0 wlan0: disabling HT as WMM/QoS is not supported by the AP
Sep 7 12:27:37 mike-ubuntu kernel: [ 115.631164] rtl8192cu 1-1:1.0 wlan0: disabling VHT as WMM/QoS is not supported by the AP
Sep 7 12:27:37 mike-ubuntu kernel: [ 115.632450] wlan0: associate with 00:13:10:e1:f9:a2 (try 1/3)
Sep 7 12:27:37 mike-ubuntu NetworkManager[868]: <info> (wlan0): supplicant interface state: authenticating -> associating
Sep 7 12:27:37 mike-ubuntu wpa_supplicant[906]: wlan0: Associated with 00:13:10:e1:f9:a2
Sep 7 12:27:37 mike-ubuntu wpa_supplicant[906]: wlan0: CTRL-EVENT-CONNECTED - Connection to 00:13:10:e1:f9:a2 completed (auth) [id=0 id_str=]
Sep 7 12:27:37 mike-ubuntu kernel: [ 115.642953] wlan0: RX AssocResp from 00:13:10:e1:f9:a2 (capab=0x421 status=0 aid=4)
Sep 7 12:27:37 mike-ubuntu kernel: [ 115.643075] wlan0: associated
Sep 7 12:27:37 mike-ubuntu kernel: [ 115.643160] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Sep 7 12:27:37 mike-ubuntu NetworkManager[868]: <info> (wlan0): supplicant interface state: associating -> completed
Sep 7 12:27:37 mike-ubuntu NetworkManager[868]: <info> Activation (wlan0/wireless) Stage 2 of 5 (Device Configure) successful. Connected to wireless network 'kaylag2'.
Sep 7 12:27:37 mike-ubuntu NetworkManager[868]: <info> Activation (wlan0) Stage 3 of 5 (IP Configure Start) scheduled.
Sep 7 12:27:37 mike-ubuntu NetworkManager[868]: <info> Activation (wlan0) Stage 3 of 5 (IP Configure Start) started...
Sep 7 12:27:37 mike-ubuntu NetworkManager[868]: <info> (wlan0): device state change: config -> ip-config (reason 'none') [50 70 0]
Sep 7 12:27:37 mike-ubuntu NetworkManager[868]: <info> Activation (wlan0) Beginning DHCPv4 transaction (timeout in 45 seconds)
Sep 7 12:27:37 mike-ubuntu NetworkManager[868]: <info> dhclient started with pid 2201
Sep 7 12:27:37 mike-ubuntu NetworkManager[868]: <info> Activation (wlan0) Beginning IP6 addrconf.
Sep 7 12:27:37 mike-ubuntu NetworkManager[868]: <info> Activation (wlan0) Stage 3 of 5 (IP Configure Start) complete.
Sep 7 12:27:37 mike-ubuntu dhclient: Internet Systems Consortium DHCP Client 4.2.4
Sep 7 12:27:37 mike-ubuntu dhclient: Copyright 2004-2012 Internet Systems Consortium.
Sep 7 12:27:37 mike-ubuntu dhclient: All rights reserved.
Sep 7 12:27:37 mike-ubuntu dhclient: For info, please visit https://www.isc.org/software/dhcp/
Sep 7 12:27:37 mike-ubuntu dhclient: Listening on LPF/wlan0/14:d6:4d:a7:0d:2e
Sep 7 12:27:37 mike-ubuntu NetworkManager[868]: <info> (wlan0): DHCPv4 state changed nbi -> preinit
Sep 7 12:27:37 mike-ubuntu dhclient: Sending on LPF/wlan0/14:d6:4d:a7:0d:2e
Sep 7 12:27:37 mike-ubuntu dhclient: Sending on Socket/fallback
Sep 7 12:27:37 mike-ubuntu dhclient: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 3 (xid=0x2a921615)
Sep 7 12:27:39 mike-ubuntu avahi-daemon[864]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::16d6:4dff:fea7:d2e.
Sep 7 12:27:39 mike-ubuntu avahi-daemon[864]: New relevant interface wlan0.IPv6 for mDNS.
Sep 7 12:27:39 mike-ubuntu avahi-daemon[864]: Registering new address record for fe80::16d6:4dff:fea7:d2e on wlan0.*.
Sep 7 12:27:40 mike-ubuntu dhclient: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 4 (xid=0x2a921615)
Sep 7 12:27:44 mike-ubuntu dhclient: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 10 (xid=0x2a921615)
Sep 7 12:27:54 mike-ubuntu dhclient: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 10 (xid=0x2a921615)
Sep 7 12:27:57 mike-ubuntu NetworkManager[868]: <info> (wlan0): IP6 addrconf timed out or failed.
Sep 7 12:27:57 mike-ubuntu NetworkManager[868]: <info> Activation (wlan0) Stage 4 of 5 (IPv6 Configure Timeout) scheduled...
Sep 7 12:27:57 mike-ubuntu NetworkManager[868]: <info> Activation (wlan0) Stage 4 of 5 (IPv6 Configure Timeout) started...
Sep 7 12:27:57 mike-ubuntu NetworkManager[868]: <info> Activation (wlan0) Stage 4 of 5 (IPv6 Configure Timeout) complete.
Sep 7 12:28:04 mike-ubuntu dhclient: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 10 (xid=0x2a921615)
Sep 7 12:28:14 mike-ubuntu dhclient: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 15 (xid=0x2a921615)
Sep 7 12:28:20 mike-ubuntu kernel: [ 158.449728] sd 6:0:0:0: [sdb] Test WP failed, assume Write Enabled
Sep 7 12:28:20 mike-ubuntu kernel: [ 158.451338] sd 6:0:0:0: [sdb] Asking for cache data failed
Sep 7 12:28:20 mike-ubuntu kernel: [ 158.451348] sd 6:0:0:0: [sdb] Assuming drive cache: write through
Sep 7 12:28:22 mike-ubuntu NetworkManager[868]: <warn> (wlan0): DHCPv4 request timed out.
Sep 7 12:28:22 mike-ubuntu NetworkManager[868]: <info> (wlan0): canceled DHCP transaction, DHCP client pid 2201
Sep 7 12:28:22 mike-ubuntu NetworkManager[868]: <info> Activation (wlan0) Stage 4 of 5 (IPv4 Configure Timeout) scheduled...
Sep 7 12:28:22 mike-ubuntu NetworkManager[868]: <info> Activation (wlan0) Stage 4 of 5 (IPv4 Configure Timeout) started...
Sep 7 12:28:22 mike-ubuntu NetworkManager[868]: <info> (wlan0): device state change: ip-config -> failed (reason 'ip-config-unavailable') [70 120 5]
Sep 7 12:28:22 mike-ubuntu NetworkManager[868]: <warn> Activation (wlan0) failed for connection 'kaylag2'
Sep 7 12:28:22 mike-ubuntu NetworkManager[868]: <info> Activation (wlan0) Stage 4 of 5 (IPv4 Configure Timeout) complete.
Sep 7 12:28:22 mike-ubuntu NetworkManager[868]: <info> (wlan0): device state change: failed -> disconnected (reason 'none') [120 30 0]
Sep 7 12:28:22 mike-ubuntu NetworkManager[868]: <info> (wlan0): deactivating device (reason 'none') [0]
Sep 7 12:28:22 mike-ubuntu avahi-daemon[864]: Withdrawing address record for fe80::16d6:4dff:fea7:d2e on wlan0.
Sep 7 12:28:22 mike-ubuntu avahi-daemon[864]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::16d6:4dff:fea7:d2e.
Sep 7 12:28:22 mike-ubuntu avahi-daemon[864]: Interface wlan0.IPv6 no longer relevant for mDNS.
Sep 7 12:28:22 mike-ubuntu kernel: [ 161.024993] wlan0: deauthenticating from 00:13:10:e1:f9:a2 by local choice (reason=3)
Sep 7 12:28:22 mike-ubuntu wpa_supplicant[906]: wlan0: CTRL-EVENT-DISCONNECTED bssid=00:00:00:00:00:00 reason=3
Sep 7 12:28:22 mike-ubuntu kernel: [ 161.040777] cfg80211: Calling CRDA to update world regulatory domain
Sep 7 12:28:22 mike-ubuntu NetworkManager[868]: <info> (wlan0): supplicant interface state: completed -> disconnected
Sep 7 12:28:22 mike-ubuntu kernel: [ 161.132211] cfg80211: World regulatory domain updated:
Sep 7 12:28:22 mike-ubuntu kernel: [ 161.132227] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Sep 7 12:28:22 mike-ubuntu kernel: [ 161.132231] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Sep 7 12:28:22 mike-ubuntu kernel: [ 161.132234] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
Sep 7 12:28:22 mike-ubuntu kernel: [ 161.132237] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
Sep 7 12:28:22 mike-ubuntu kernel: [ 161.132239] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Sep 7 12:28:22 mike-ubuntu kernel: [ 161.132242] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Sep 7 12:28:23 mike-ubuntu avahi-daemon[864]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::16d6:4dff:fea7:d2e.
Sep 7 12:28:23 mike-ubuntu avahi-daemon[864]: New relevant interface wlan0.IPv6 for mDNS.
Sep 7 12:28:23 mike-ubuntu avahi-daemon[864]: Registering new address record for fe80::16d6:4dff:fea7:d2e on wlan0.*.
