I don't know why but it randomly pops up sometimes every hour sometimes every 30 minutes with the message "The software is up to date"
This would help you
  • Open Software Sources by running following command in terminal(Ctrl+Alt+T):
    sudo software-properties-gtk
  • Then go to Updates tab.
  • Chose Never Under Automatically Check for Updates option.
  • Close the window.
  • Update your repository by:
    sudo apt-get update.
After that it should not pop-up any message. Repeat same step if you again want Ubuntu to pop-up for you. Just change Never to any other option. Try it once.. Reply if something goes wrong..
Saurav Kumar
  • 15,174
