I've installed Ubuntu 12.04.3 64-bit as a guest under VMplayer running on my Win7 host.
After Ubuntu installs, I launch and open a terminal.
I then enter the following:
sudo apt-get update
sudo apt-get install wine
sudo apt-get install xvfb
sudo apt-get install xfonts-100dpi xfonts-75dpi xfonts-scalable xfonts-cyrillic
When I launch xvfb, I get the following error:
“[dix] Could not init font path element /var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType, removing from list!”
"x-ttcidfont-conf" should have been installed with "wine" as I got the same EULA when I install manually. However, it never gets recognized and when I check font folders, they're empty.
I've tried these steps as well:
  1. Alternate attempt 1:
    • sudo apt-get -y install x-ttcidfont-conf cabextract ttf-mscorefonts-installer
    • sudo dpkg-reconfigure x-ttcidfont-conf
  2. Alternate attempt 2:
    • Reset Ubuntu
    • At login screen: Press CtrlAltF1
    • Login
    • kill x server: sudo service lightdm stop
    • generate new xorg.conf file: sudo X -configure
      • This will create a 'xorg.conf.new' file in your current dir
    • return to GUI: sudo start lightdm
    • Login through UI
    • Open & edit xorg.conf.new and add the following two lines:
      FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID"
      FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
    • Save & exit
    • Logout of UI
    • Login
    • rename and move: sudo mv xorg.conf.new /etc/X11/xorg.conf
I fully admit I'm a linux/ubuntu/xvfb noob...but I am good at Google searches and nothing seems to work.
What am I missing?
I've tried:
[sudo] password for <user>:
Reading package lists... Done
Building dependency tree
x-ttcidfont-conf is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 17 not - upgraded.
and still get the same error message.
I've also tried:
  1. sudo apt-get upgrade
  2. Restarted ubuntu
  3. retried
Get same results. :-(
There is an in-house shell script that launches Xvfb followed by an application and apparently just hangs as a result. The first line in the shell script is:
Xvfb :2 &
And simply executing that command outside of the shell script causes the same error.
I've read in one of the many pages to help resolve this that I need an xorg.conf in a folder to point to font folders. I tried to create this and for the other fonts such as xfont-100dpi, xfont-75dpi, etc. there is content in the folders. Why am I not able to get any content in the equivalent font folder for x-ttcidfont-conf TrueType font?
gdaemon
  • 31
You are missing the package x-ttcidfont-conf. A simple sudo apt-get -y install x-ttcidfont-conf should solve the problem.
Braiam
  • 69,112
I found that by executing the following command, I was able to resolve the problem:
mkfontdir
Thanks for your help.
gdaemon
  • 31
