I have changed PS1 variable in /etc/bash.bashrc to
PS1="\n\[\033[0;37m\]\342\224\214\342\224\200\$(if [[ \$? == 0 ]]; then echo \"[\[\033[0;32m\]\[\033[01;32m\]\342\234\223\[\033[0;37m\]]\342\224\200\"; else echo \"[\[\033[0;32m\]\[\033[01;31m\]\342\234\227\[\033[0;37m\]]\342\224\200\"; fi)[$(if [[ ${EUID} == 0 ]]; then echo '\[\033[0;31m\]\h'; else echo '\[\033[0;33m\]\u\[\033[0;37m\]@\[\033[0;96m\]\h'; fi)\[\033[0;37m\]]\342\224\200[\[\033[0;32m\]\w\[\033[0;37m\]]\n\[\033[0;37m\]\342\224\224\342\224\200\342\224\200\342\225\274 \[\033[0m\]"
Which works fine with all the commands. But when I run sudo -i command, PS1 value goes to the default. To get back the color scheme, I have to run PS1=<same value> manually. Any idea what might be causing this behaviour?
Braiam
  • 69,112
I was going to add PS1, following the answer by Alaa Ali, and I've found the following lines:
# uncomment for a colored prompt, if the terminal has the capability; turned
# off by default to not distract the user: the focus in a terminal window
# should be on the output of commands, not on the prompt
force_color_prompt=no
I've changed it to force_color_prompt=yes, then exit, login back, and voilĂ ! Colors!
I'm on Ubuntu (disco), hope that this help. I think that it's better than PS1 because there's a lot of code that depends on this variable, I don't know exactly what's doing, but somebody has written it, I don't want to waste his/her time :-)
funder7
  • 196
Add the PS1 line to /root/.bashrc.
The reason why the color goes back to default is because when you do sudo -i, it "simulates" a root login, and in turn sources (applies) root's .bashrc, which brings the color back to the default. So adding the PS1 line to root's .bashrc should do the trick.
Alaa Ali
  • 32,213
