I am having the following errors, while starting ntop, i.e. when I type sudo ntop:
Error#1:
Fri Sep  6 09:01:52 2013  **ERROR** GeoIP: unable to load file GeoLiteCity.dat
Fri Sep  6 09:01:52 2013  **ERROR** GeoIP: unable to load ASN file GeoIPASNum.dat
Error#2:
Fri Sep  6 09:01:52 2013  INITWEB: Initializing TCP/IP socket connections for web server
Fri Sep  6 09:01:52 2013  **ERROR** INITWEB: binding problem - 'Address already in use'(98)
Fri Sep  6 09:01:52 2013  Check if another instance of ntop is running
Fri Sep  6 09:01:52 2013  or if the current user (-u) can bind to the specified port
Fri Sep  6 09:01:52 2013  **FATAL_ERROR** Binding problem, ntop shutting down...
Can anyone please help how to solve this?
Mitch
  • 109,787
This is what a top uses to populate the geolocation information of the remote network traffic.
To correct this:
wget -N http://geolite.maxmind.com/download/geoip/database/GeoLiteCity.dat.gz
gunzip GeoLiteCity.dat.gz
wget -N http://download.maxmind.com/download/geoip/database/asnum/GeoIPASNum.dat.gz
gunzip GeoIPASNum.dat.gz
sudo mkdir -p /usr/share/GeoIP/
sudo mv GeoLiteCity.dat /usr/share/GeoIP/
sudo mv GeoIPASNum.dat /usr/share/GeoIP/
You may like to update the GeoIP monthly to keep the data up to date.
Source: http://www.mikereamy.com/2013/11/ntop-geoip-error/
Rucent88
  • 2,058
This means you are missing GeoIP. This should download, set the directory if not there and "install" it:
sudo mkdir -p /usr/local/share/GeoIP/
sudo mv GeoLiteCity.dat /usr/local/share/GeoIP/
Rinzwind
  • 309,379
