Is there a way to extract files of tar.7z format using command line tools in Ubuntu?
Yes - the package p7zip / p7zip-full provides a command-line application to zip/unzip 7z files. The command is simply 7z.
You can combine a 7z / tar call using a pipe:
7z x -so yourfile.tar.7z | tar xf - -C target_dir
where target_dir is a already-existing directory.
- 7,502
Install p7zip-full if not already installed:
sudo apt-get install p7zip-fullexecute this command to extract .tar.7z file(go to directory where is your file, if
myfile.tar.7zis your file name):7za x myfile.tar.7z tar -xvf myfile.tarThat's it. Actually first command extracts in .tar file then next command extracts it completely.
- 15,174
Make sure that 7zip is installed, if not, just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command(s) below:
To install the command line utility do:
Once done you can do the following to extract:
7z e <file_name>.tar.7z
To extract with full paths:
7z x <file_name>.tar.7z
To specify a path to extract to:
7z x <file_name>.tar.7z -opath
7z does not allow spaces between -o and path.
- 119,640
- 109,787
