37
I have the following sql command which I usually run in phpmyadmin by selecting the database, then running it in the command window.
DELETE FROM `wp_posts` WHERE `post_type` = "attachment"
However I've never done this via terminal before. My question is, how do I "point" this command to a specific database and then run it?
Zanna
  • 72,312
jc.yin
  • 561
7 Answers7
46
For you to run it from terminal, you need to be logged into mysql first and then you execute your program. The ideal code would be
mysql -u(username) -p(password) (the name of the database) -e "DELETE FROM `wp_posts` WHERE `post_type` = "attachment""
I`m sure this works, hope it helps
sosytee
  • 2,738
19
I think you have forgot your user name for mySQL. so please enter the correct user name and password when you type mysql command. for eg
$ mysql   -u  root   -p
Enter Password:
Note: Default user name and password is root
muru
  • 207,228
10
Just type the following command in terminal to use mysql interpreter:
mysql -u root -p database_name
Enter your password, then you can run your mysql commands.
Another way is to use:
mysql -u root -p database_name << eof
eof
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
Try this:
mysql --host *HOST_IP* --user *USER* --password=*PASSWORD* -D *DATABASE_NAME* -e "DELETE FROM `wp_posts` WHERE `post_type` = "attachment" ;
Bruni
  • 11,099
tej18
  • 83
Using the MySQL CLI client.
$ mysql -u <user> -p
mysql> use <your-database>
mysql> DELETE FROM `wp_posts` WHERE `post_type` = "attachment"
Notice that I'm using -u and username, but in -p I'm not setting anything. MySQL will ask you for your password.
And if you're trying to use it inline, you can use
$ mysql -u <user> -p <your-database> -e "DELETE FROM `wp_posts` WHERE `post_type` = 'attachment'"
Here, notice that I'm using also -e argument. It stands for execute.
Pro tip
In MySQL client you can use:
mysql> show databases;
if you want to view all dabatases in your server. And you can use:
mysql> use <database>;
mysql> show tables;
if you want to view all tables into a database.
I'm using $ and mysql> as prompts, $ means your Linux terminal, and mysql>, MySQL client.
-1
There is a series of steps to Execute MySQL in Linux Ubuntu Terminal.
  1. Execute MySQL Client using the following command: mysql -u root -p
  2. It is important to Create a New Database first using the command: create database demo_db;
  3. Then you have to Authorize the Database using the command: grant all on demo_db.* to ‘testuser’ identified by ‘12345’;
  4. Then Log in from the Database itself using the command: mysql -u testuser -p
  5. Then, you can actually start with the actual SQL Commands.
I referred to the article http://www.codingalpha.com/run-mysql-database-linux-ubuntu/ where they have explained perfect steps to Execute MySQL in Linux Ubuntu! Hope I got your MySQL Running Perfectly.
-2
Okay basically it was "SELECT databasename;" then executing my command.
jc.yin
  • 561
