Are there any terminals that can serve as an alternative to gnome-terminal. Do these alternatives have other/extra features ?
Feel free to edit in info on features and/or maintenance.
There is a blog post at OMG! Ubuntu! that lists five alternatives to gnome-terminal. Another post at Tech Drive-in adds even more other ones. For screenshots, see these websites.
Terminator
"It allows you to split its main window into as many tiles anyone could ever need."
sudo apt-get install terminator
Here are some of its features:
- Arrange terminals in a grid
- Tabs
- Drag and drop to re-order terminals
- Lots of keyboard shortcuts
- Save multiple layouts and profiles via GUI preferences editor
- Simultaneous typing to arbitrary groups of terminals
Tilda
"a configurable “Quake-style” terminal emulator, meaning that it slides down from the top of your desktop when a user-configurable key (default is F1)" No longer actively maintained?
sudo apt-get install tilda
As said at linuxlibrary: "Tilda does seem to offer more customization options than similar drop-down style terminals":
- Highly customizable interface.
- Set the level of transparency for the main Tilda window.
- Unique built-in color schemes.
- Users are able to reduce the main window to its most minimal state.
Guake
"similar in functionality to Tilda"
sudo apt-get install guake
Stjerm
"comparable to [...] Guake and Tilda. It’s also very lightweight, features tabs, and an option to toggle fullscreen"
sudo apt-get install stjerm
Yakuake
"KDE-native"
sudo apt-get install yakuake
CLI companion
mostly to learn terminal commands
sudo add-apt-repository ppa:clicompanion-devs/clicompanion-nightlies
sudo apt-get update
sudo apt-get install clicompanion
or download a .deb file for it from here.
Eterm
"Eterm is the lightest of them all"
sudo apt-get install eterm
ROXTerm
"Supports features like drag & drop of items into Terminal windows"
sudo apt-get install roxterm
Aterm:
"Extra features include fast pseudo-transparency, optional off-focus fading of text"
sudo apt-get install aterm
Wterm
"An extensive set or runtime options are available resulting in a very customizable terminal emulator" No longer actively maintained?
TermKit
"a command line based system made on top of WebKit"
Terminology
As rajagenupula mentions there is also terminology.
It "can do a lot of things you wouldn't expect from a terminal emulator, like displaying thumbnails for images, videos and documents and furthermore, it also allows you to preview those files directly from Terminology" (quote from webupd8)
Kitty
"The fast, feature-rich, GPU based terminal emulator"
sudo apt-get install kitty
A productive terminal emulator for power users, some of its features:
- split window into panes and navigate between them with the keybaord
- display images inside the terminal
- pick unicode characters like emojis through a visual menu
For a full list, see the kitty website.
- 123
- 29,392
You can use terminology,:) . its everything. its not just a simple terminal.
By using terminology you can preview images ,you can play videos from the terminal only.you no need to open other file managers. its everything.
to install it open your terminal and type
sudo add-apt-repository ppa:hannes-janetzek/enlightenment-svn
sudo apt-get update
sudo apt-get install terminology
then you access it, from unity dash. just install it once. I am sure you will surprised to see what you could do in the terminal.
look at the image , that will tell you everything that I am talking
one more feature just now figured out that , at a time you can with 5 terminal with out clicking at new time every time.
- 105,327
- 107
- 262
- 331
I suggest Byobu
Not only it has capability of splitting windows, but also there's indicators for battery %, network strength, clock, etc. If you attach a session there, it will also be transferred to tty. There's a somewhat of learning curve for splitting windows, but that is not too bad. Ctrl+a, then :, then type split -h or split -v. There's also ability to have new tabs/windows with F2 key
But since it isn't really terminal emulator (as discussed in the comments bellow ), I suggest sakura. It's a cross between minimalism of xterm and configurability of gnome-terminal. Just today I tried to install gnome-terminal in my Arch installation, and it didn't go through for whatever reason . . .sakura was a good alternative, easy to use, easy to configure.
- 107,582
Best is to install xfce4-terminal. It works fine in Gnome3, has an unobtrusive scrollbar, has a nice pastel theme, and has transparency.
- 31
Starting from GNOME 42, a new terminal, called Console, is available. It is an alternative to Ubuntu’s default GNOME Terminal. It is not a 1:1 replacement, it is designed to be a simple terminal emulator for the average user to carry out simple CLI tasks and aims to be a ‘core’ app for GNOME.
According to a dedicated news from OMG! Ubuntu!, probably GNOME team preferred to create a new terminal for the switch to GTK4 than adapting the GNOME terminal codebase.
Console is not automatically installed in Ubuntu 22.04, in fact it is not intended for GNOME Terminal/Tilix replacement: according to the GitLab page "Console aims to serve the casual linux user who rarely needs a terminal."
Console is available in the jammy universe repo and may be installed by running the command:
sudo apt install gnome-console
Picture from OMG! Ubuntu! (side by side with the new text editor):
- 9,511
I wrote Fourterm, Terminator-like terminal written in GTK+/Vala. It's faster, but it has less features. https://github.com/lzap/fourterm
- 728
XTerm is also very good! This article covers lot of its features: http://lukas.zapletalovi.com/2013/07/hidden-gems-of-xterm.html
- 728
