When I run the sudo apt-get update, it results in the following
 Reading package lists... Done
 W: GPG error: http://ppa.launchpad.net lucid Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY A1715D88E1DF1F24
 W: GPG error: http://ppa.launchpad.net lucid Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 551CE2FB4CBEDD5A
 W: GPG error: http://ppa.launchpad.net lucid Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 1E9377A2BA9EF27F
By googling I came to know the key is missing, and it can be obtained by running the following command with the corresponding hexadecimal numbers
 saikirangvr@ubuntu:~$ sudo gpg --keyserver subkeys.pgp.net --recv 551CE2FB4CBEDD5A
But I was not able to fix this as this gave me the error
gpg: WARNING: unsafe ownership on configuration file `/home/saikirangvr/.gnupg/gpg.conf'
gpg: external program calls are disabled due to unsafe options file permissions
gpg: keyserver communications error: general error
gpg: keyserver receive failed: general error
I tried many times but I was unable to fix. I was behind a proxy server in my college and I have configured the Ubuntu well to use behind the proxy.
After using
 sudo chown -R saikirangvr:saikirangvr /home/saikirangvr/.gnupg
the problem of unsafe ownership was gone, and it gave the following....
 sai@ubuntu:~/gpgpu-sim/ispass2009-benchmarks$ gpg --keyserver keyserver.ubuntu.com --recv 1E9377A2BA9EF27F
 gpg: requesting key BA9EF27F from hkp server keyserver.ubuntu.com
 gpgkeys: key 1E9377A2BA9EF27F not found on keyserver
 gpg: no valid OpenPGP data found.
 gpg: Total number processed: 0
 sai@ubuntu:~/gpgpu-sim/ispass2009-benchmarks$ gpg --keyserver subkeys.pgp.net --recv 1E9377A2BA9EF27F
 gpg: requesting key BA9EF27F from hkp server subkeys.pgp.net
the result of adding the ppa
sai@ubuntu:~$ sudo add-apt-repository ppa:nilarimogard/webupd8
[sudo] password for sai:
Error reading https://launchpad.net/api/1.0/~nilarimogard/+archive/webupd8: Couldn't resolve host 'launchpad.net'
same error occurs when using launch pad get keys
 sai@ubuntu:~$ sudo launchpad-getkeys
 Please wait... launchpad-getkeys is running an update so
 it can detect the missing GPG keys
 Trying to import all the missing keys
 gpg: requesting key 4C9D234C from hkp server keyserver.ubuntu.com
 gpgkeys: key 531EE72F4C9D234C not found on keyserver
 launchpad-getkeys has finished importing all missing GPG keys.
 Try running sudo apt-get update - you shouldn't see any key
  errors anymore
What is the problem. *Is there any other method to solve this like through GUI *.......
dessert
  • 40,956
sai kiran grandhi
  • 193
  • 14
Try the following :
$ sudo apt-get update
$ sudo apt-get install launchpad-getkeys
Once installed, to import all the missing GPG keys for your PPAs, simply use the following command:
It will run an update and try to import all missing GPG keys for you. After executing it, hope you don't see any GPG errors.
The link is a reference to the solution.
shivshnkr
  • 5,113
Fix the ownership of the .gnupg directory:
After that repeat the key importing command.
By the way, the gpg command has to be issued without sudo, in this way you will not break your file's ownership.
Frantique
  • 8,673
