OUTPUT - sudo lshw -C network
*-network
description: Network controller
product: BCM4311 802.11b/g WLAN
vendor: Broadcom Corporation
physical id: 0
bus info: pci@0000:0b:00.0
version: 01
width: 32 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=wl latency=0
resources: irq:16 memory:efcfc000-efcfffff
*-network UNCLAIMED
description: Ethernet controller
product: BCM4401-B0 100Base-TX
physical id: 0
bus info: pci@0000:03:00.0
version: 02
width: 32 bits
clock: 33MHz
capabilities: pm bus_master cap_list
configuration: latency=64
resources: memory:ef9fe000-ef9fffff
OUTPUT - ifconfig -a
lo
Link encap:Local Loopback
inet addr:127.0.0.1  Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING  MTU:65536  Metric:1
RX packets:259 errors:0 dropped:0 overruns:0 frame:0
TX packets:259 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
          RX bytes:33926 (33.9 KB)
TX bytes:33926 (33.9 KB)
Content of path - etc/udev/rules.d/70-persistent-net.rules
# PCI device 0x14e4:/sys/devices/pci0000:00/0000:00:1e.0/0000:03:00.0/ssb1:0 (b44)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="00:19:b9:5a:f6:eb", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth0"
OUTPUT - sudo ifconfig eth0
    eth0: ERROR while getting interface flags: No such device
OUTPUT - sudo ifup eth0
    Ignoring unknown interface eth0=eth0.
Thomas Ward
  • 78,878
Please open a terminal and do:
sudo apt-get remove --purge bcmwl-kernel-source
Hook up the ethernet temporarily and do:
sudo modprobe b44
Now your ethernet should be working and able to connect. Then do:
sudo apt-get install linux-firmware-nonfree
Everything should be working correctly after a reboot.
chili555
  • 61,330
