Have sort of a weird question. I'd like to create my own custom Ubuntu load, install specific software, change the interface and theme, then take that and create a live USB from it.
I'm making it for some people that are not computer smart, so I want to make it non-persistent, so if they mess it up, they can just reboot and have the exact same desktop from which they started. I was thinking maybe there is a way to convert a VirtualBox Ubuntu, or something like that. I'm not the best at the terminal, and I'd like to test it as I go to make sure that everything is working.
Any ideas?
Seth
  • 59,332
jjmil03
  • 71
Create a custom .iso
Graphical way to customize a clean iso (recommended)
  1. Install the latest Ubuntu Builder from here
  2. Choose "Select ISO > From local disk"
  3. Choose 'Synaptic' to customize packages or 'Desktop' to run easily a VM with the ISO to make changes
  4. Click 'Build ISO' to save your customized ISO somewhere
Guide here
To customize a clean .iso from the command line
  1. You can use the 'Ubuntu Customization Kit' which can be installed like this:
    sudo apt-get install uck
  2. Launch it from the dash
  3. Follow the instructions
  4. Eventually, you will be given an option to run the console of the iso to install/remove packages and make customizations
You will need a pre downloaded ISO to be the base for your customizations
(source)
To create a copy of your existing Ubuntu installation
You can use the tool System Imager, available from here
System Imager is a tool that images your running system and allows you to make a image of your running machine and install it on another. System Imager is based on the work of Remastersys.
This is probably easier if you aren't familiar with the command line. It'll be easier to make customizations
To test the ISO without writing to USB
  1. Install qemu with
    sudo apt-get install qemu
  2. Run it with the command
    qemu -cdrom /path/to/your/.iso -boot d -m 256
Finally
To write the iso to a USB and make it non persistent
  1. Run "Startup Disk Creator" from the Dash
  2. Choose your .iso and target USB drive
  3. Set "documents and settings" option to "discarded on shutdown"
NOTE: This is only non persistent when booting from the USB, not in the final installed system
kiri
  • 28,986
Update: As of 2022, it appears live-build has been replaced by Debian Live.
Original answer:
Look at this, live-build contains the scripts that build a Debian Live system image from a configuration directory.
# apt-get install live-build
mkdir -p /usr/src/live
cd /usr/src/live
lb clean
echo "Configure:"
lb config noauto \
    --bootappend-live toram \
    --package-lists minimal \
    --package aufs-util \
    --linux-flavours clean \
    --binary-images usb-hdd \
    --bootloader grub \
    --verbose
echo "Building..."
lb build --verbose
mpb
  • 1,455
