When I try to install new package with apt-get install, it doesn't work. apt-get update doesn't work too.
Do you know how to reinstall it to work again?
Output from sudo dpkg --configure -a :
dpkg: dependency problems prevent configuration of tvbrowser:
tvbrowser depends on sun-java6-jre | sun-java5-jre; however:
Package sun-java6-jre is not installed.
Package sun-java5-jre is not installed.
dpkg: error processing tvbrowser (--configure):
dependency problems - leaving unconfigured
tvbrowser
Output from sudo apt-get install sun-java6-jre
Reading package lists... Done
Building dependency tree
Package sun-java6-jre is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package sun-java6-jre has no installation candidate
This pastebin has the output of find /etc/apt/ -name '*.list' -ls -exec cat {} \; > repositories.txt .
