Works well with nautilus and settings. Other places: I tap, cursor points, no further action. Guide me. I need it. What to do?
Asked
Active
Viewed 5,270 times
I've had the same issue; the good news is that there's a patch to fix it -- see (1) and (2). Follow the steps below (at your own risk) to apply the patch, compile the source, and install the patched packages:
- Install the build dependencies for the source package
sudo apt-get build-dep xorg-server - Download the xorg-server package
sudo apt-get source xorg-server cdto the directory created by the previous command- Download the patch, which can be found at 2
- Apply the patch you just downloaded
patch -p0 < ~/Downloads/touch-fix.patch(assuming the patch is in ~/Downloads) - Compile and generate the packages (.deb files)
debuild -b -us -uc - Install the packages
sudo dpkg -i ../*.deb - Restart your machine
I hope this helps.
(1) https://bugs.freedesktop.org/show_bug.cgi?id=56578
(2) https://bugs.freedesktop.org/attachment.cgi?id=78125
Videonauth
- 33,815
