How to install CUDA 5.5 under Ubuntu 12.04 LTS 64-bit?
Eliah Kagan
  • 119,640
eesa
  • 61
STEP I – Driver installation (if you choose the regular drivers)
This section remains almost unchanged. Download the Nvidia drivers for Linux from their website, making sure to select 32 or 64-bit Linux based on your system.
Make sure the requisite tools are installed using the following command -
sudo apt-get install freeglut3-dev build-essential libx11-dev libxmu-dev libxi-dev libgl1-mesa-glx libglu1-mesa libglu1-mesa-dev
Next, blacklist the required modules (so that they don’t interfere with the driver installation) -
sudo nano /etc/modprobe.d/blacklist.conf
Add the following lines to the end of the file, one per line, and save it when done -
blacklist amd76x_edac
blacklist vga16fb
blacklist nouveau
blacklist rivafb
blacklist nvidiafb
blacklist rivatv
In order to get rid of any nVidia residuals, run the following command in a terminal -
sudo apt-get remove --purge nvidia*
This may take a while, so be patient. Once it’s done, reboot your machine. At the login screen, don’t login just yet. Press Ctrl+Alt+F1 to switch to a text-based login, and switch to the directory which contains the downloaded driver. Run the following commands -
sudo service lightdm stop
chmod +x NVIDIA*.run
where NVIDIA*.run is the full name of your driver. Next, start the installation with -
sudo ./NVIDIA*.run
Follow the onscreen instructions. If the installer throws up an error about nouveau still running, allow it to create a blacklist for nouveau, quit the installation and reboot. In that case, run the following commands again -
sudo ./NVIDIA*.run
The installation should now proceed smoothly. When it asks you if you want the 32-bit libraries and if you want it to edit xorg.conf to use these drivers by default, allow both.
Reboot once the installation completes.
STEP II – CUDA toolkit installation
Download the CUDA toolkit (I used the Ubuntu 11.10 64-bit version). Navigate to the directory that contains the downloaded CUDA toolkit package, and run the following command -
chmod +x cuda*.run
sudo ./cuda*.run
where cuda*.run is the full name of the downloaded CUDA toolkit. Accept the license that appears. Next, choose to install the driver if you’ve not done so already (this is the development version). Installation of the driver will require switching to a text-based shell (Ctrl+Alt+F1), stopping lightdm as detailed in the previous step and running the toolkit installer as superuser. The CUDA 5.0 toolkit installation is compulsory, while that of the included samples isn’t. Allow the installer to proceed with default locations unless you have specific reasons for not doing so. This makes for easier troubleshooting in the future.
This process might take a while depending upon your system config. Once it’s done, double check the summary screen to make sure everything is in place. If the installation of the samples fails (which it does more often than not), it’s probably due to one or more missing libraries. In that case, install the required libraries and rerun the installer, choosing to install the samples alone.
To make sure the necessary environment variables (PATH and LD_LIBRARY_PATH) are modified every time you access a terminal, add the requisite lines (from the summary screen) to the end of ~/.bashrc as follows -
32 bit systems -
export PATH=$PATH:/usr/local/cuda-5.0/bin
export LD_LIBRARY_PATH=/usr/local/cuda-5.0/lib
64 bit systems -
export LD_LIBRARY_PATH=/usr/local/cuda-5.0/lib64:/lib
The paths used above will vary based on the install directory you choose for the toolkit. This wraps up the arguably simpler setup (compared to CUDA 4.x for Linux users), although the samples’ installation still suffers from dependency hell.
STEP III – CUDA samples installation and troubleshooting
While the installation of the samples should be straightforward (simply run the all in one toolkit installer), it’s often not all that easy. If you’re getting an error similar to “Samples installation failed due to missing libraries – libglut.so not found”, it’s typically because the installer looks for libglut.so and not variants (like libglut.so.3). To fix this, we’ll have to create softlinks so the installer can track down these files.
Determine if variants of libglut.so are present as follows -
sudo find /usr -name libglut\*
On my 64-bit installation of Ubuntu 12.04, this output the following text -
/usr/lib/x86_64-linux-gnu/libglut.so.3
/usr/lib/x86_64-linux-gnu/libglut.so.3.9.0
/usr/lib/x86_64-linux-gnu/libglut.a
Now that a variant of libglut.so (that is, libglut.so.3) has been found, we can create a softlink to it -
sudo ln -s /usr/lib/x86_64-linux-gnu/libglut.so.3 /usr/lib/libglut.so
Next, rerun the all in one installer choosing to install only the samples this time around. That should fix the “Missing libraries” error that cropped up previously.
Further reading resources can be found here if you’re looking for books on CUDA and GPGPU programming in general.
Credit goes Here
Raja G
  • 105,327
  • 107
  • 262
  • 331
Prerequisites :
  1. 2 files:
    cuda-repo-ubuntu1204_5.5-0_amd64.deb - 80 KB
    cuda_5.5.22_linux_64.run - 900Mb
    These files are found in Nvidia Website under CUDA category.
    I have downloaded for Ubuntu 12.04 64 bit, download according to your OS specification
    The .run file is the setup which has
    • Nvidia Drivers
    • Cuda Tool-kit
    • Cuda Samples
    Copy these files in Ubuntu Machine to the /home/<user>/Downloads directory.
  2. In Ubuntu Machine, configure network and run the command in terminal:
    sudo apt-get update
    sudo apt-get remove --purge nvidia-*
    sudo apt-get autoclean
    sudo apt-get autoremove
    Reboot the machine.
    Open terminal and browse to the downloaded files location
    sudo dpkg -i cuda-repo-ubuntu1204_5.5-0_amd64.deb
    sudo apt-get update
    We need to disable the GUI, for that:
    The screen goes to terminal mode , enter Ctrl+Alt+F1. Enter the username and password.
    Now browse to the location where the RUN file is downloaded and do:
    sudo sh cuda_5.5.22_linux_64.run
    It takes a while to process and then, you will get a "User license agreement", scroll down to the bottom of the page and select Accept.
    You will be prompted for further installation step, just enter yes or hit enter.
    Now the installation takes place, once its done you will get the status of the Files installed saying as SUCCESS.
    Reboot the machine.
    Ubuntu must start with GUI, login , open terminal and hit the command :
    sudo find / -name cuda
    The output is displayed with the location of Cuda files.
Alaa Ali
  • 32,213
