this is very weird. I open google earth and search for "athens, greece" for example, and even though it will through a pin on top of the correct location, the google earth globe will turn and zoom in towards a location in the sahara desert!
Could this be related to the regional settings on the computer?
nass@stardust:~$ locale
LANG=en_US.UTF-8
LANGUAGE=
LC_CTYPE="en_US.UTF-8"
LC_NUMERIC=el_GR.UTF-8
LC_TIME=el_GR.UTF-8
LC_COLLATE="en_US.UTF-8"
LC_MONETARY=el_GR.UTF-8
LC_MESSAGES="en_US.UTF-8"
LC_PAPER=el_GR.UTF-8
LC_NAME=el_GR.UTF-8
LC_ADDRESS=el_GR.UTF-8
LC_TELEPHONE=el_GR.UTF-8
LC_MEASUREMENT=el_GR.UTF-8
LC_IDENTIFICATION=el_GR.UTF-8
LC_ALL=
What else could it be?
Jorge Castro
  • 73,717
nass
  • 1,442
  • 20
  • 34
With google-earth-pro-stable-7.3.2.5776-0.x86_64, I use LC_NUMERIC=C to fix the problem while keeping the language of the application unchanged. You can run:
LC_NUMERIC=C google-earth-pro
or edit /opt/google/earth/pro/googleearth to add this just after the header of file :
export LC_NUMERIC=C
tinlyx
  • 3,328
gilles
  • 61
I can verify that by changing the regional settings to en_US.UTF-8 the problem vanishes. The obvious difference is that greek uses 'comma' as a decimal separator and that mixes google earth somehow.
I am not sure if this is a bug on google-earth's code (since this error does not show up in,say, windows OS) or in ubuntu. But they should probably be notified.
nass
  • 1,442
  • 20
  • 34
This solution worked for me:
https://bugs.launchpad.net/ubuntu/+source/googleearth-package/+bug/1160289
These are the instructions I followed:
"I created a script and named it "earth.sh" (without the quotes).
  sudo gedit earth.sh
and placed the following lines inside it:
 #!/bin/bash
 LANG=en_US google-earth
Then I placed said script inside /opt/google/earth/free:
 sudo cp earth.sh /opt/google/earth/free
Then I opened /usr/share/applications/google-earth.desktop:
 sudo gedit /usr/share/applications/google-earth.desktop
and changed the "exec" command to "/opt/google/earth/free/earth.sh".
Now google earth opens and the search function works ok even if the language is not US english."
Definitively its an issue with the regional settings.
rafmunozf
  • 187
Between the last line starting with a # and FindPath(), insert LANG=en_US and save
it works just fine on my Lubuntu 18.04 / Google Earth Pro 7.3.1.4507 (64-bit) with Swedish locale. There are no problems with non-english letters (Å, Ä, Ö)
So that part of the file now looks like this:
# Function to find the real directory a program resides in.
LANG=en_US
FindPath()
Fabby
  • 35,017
