Many times I need to extract different kinds of archived files using commad-line. But not all the time I remember the exact command for any type of file archive. So, I have to waste time and search again. How can I avoid this?
Asked
Active
Viewed 8,324 times
18
The dtrx command is your friend on that matter.
It uncompresses any archive file by guessing its type. It will also make sure the files you uncompress will be put in a new directory ; avoiding messing up the current working dir with tons of files.
Install
sudo aptitude install dtrx
Usage
dtrx stuff.zip
Thomasleveil
- 281
- 2
- 6
16
You can use the following shell script (I named it extract and I put it in ~/bin):
#!/bin/bash if [ $# -lt 1 ];then echo "Usage: `basename $0` FILES" exit 1 fi # I found the following function at https://unix.stackexchange.com/a/168/37944 # which I improved it a little. Many thanks to sydo for this idea. extract () { for arg in $@ ; do if [ -f $arg ] ; then case $arg in *.tar.bz2) tar xjf $arg ;; *.tar.gz) tar xzf $arg ;; *.bz2) bunzip2 $arg ;; *.gz) gunzip $arg ;; *.tar) tar xf $arg ;; *.tbz2) tar xjf $arg ;; *.tgz) tar xzf $arg ;; *.zip) unzip $arg ;; *.Z) uncompress $arg ;; *.rar) rar x $arg ;; # 'rar' must to be installed *.jar) jar -xvf $arg ;; # 'jdk' must to be installed *) echo "'$arg' cannot be extracted via extract()" ;; esac else echo "'$arg' is not a valid file" fi done } extract $@
Don't forget to make the script executable:
chmod +x ~/bin/extract
Usage:
extract file_1 file_2 ... file_n
Radu Rădeanu
- 174,089
- 51
- 332
- 407
