I am currently trying to install a php extension on my computer. I am in the process of developing a new site and I am using LAMPP. I used PECL to install the syck YAML extension so that I can parse YAML to a PHP array in a file that will run daily with cronjobs.
In the process of trying to install it, I broke LAMPP and had to re-install it, but I got the extension installed. Here's the kicker! The extension was installed on PHP5 that is called by the terminal.
If I:
# php ./politicianupdate.php
It runs as it should, but it is not using the php installation inside of lampp, which is a problem because the php being ran from the terminal is not linked up to my databases, which I need to keep the data current.
Two things I need to figure out: how I can call a .php file from the terminal using the php installation in lampp, and the other thing I need to know is how can I point a PECL/PEAR installation at the installation of php in lampp?
The output of whereis php is:
php: /usr/bin/php /usr/bin/X11/php /usr/share/php /opt/lampp/bin/php /usr/share/man/man1/php.1.gz
