I mistakenly deleted some important zip files from my micro-sd card. I want to do data recovery on my micro-sd card. Before doing that I want take image backup of my sd card data, so that I can have backup of my micro-sd card data in case of any crash. From the link askubuntu I came to know that dd_rescue command will do the job.
This link GNU ddrescue Manual provide few examples for how to do data backup. But I couldn't find the exact command to take data backup from sd card to a image file.
What command I need to provide to take image backup of my micro-sd card?
Thanks for the support
Since you have no errors on the device you don't have to use "dd_rescue". "dd" is sufficient.
I don't know your system configuration. Therefore I suppose your SD card is device /dev/sdx. To create an image using dd please enter the following commands:
dd if=/dev/sdx of=backup-image.img
It's a good idea to unmount the partitions of the SD card before.
I hope this helps?
tpf
  • 377
