How do they differ. What are their functionality. I'm new to ubuntu and i'm using ubuntu 12.04LTS.
Here are their contents.
xorg.conf
 # nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 304.88  (buildmeister@swio-display-x86-rhel47-14)  Wed Mar 27 15:36:45 PDT 2013
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0"
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Unknown"
    HorizSync       28.0 - 33.0
    VertRefresh     43.0 - 72.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
xorg.conf.failsafe
Section "Device"
    Identifier  "Configured Video Device"
    Driver      "vesa"
EndSection
Section "Monitor"
    Identifier  "Configured Monitor"
EndSection
Section "Screen"
    Identifier  "Default Screen"
    Monitor     "Configured Monitor"
    Device      "Configured Video Device"
EndSection
  • why is xorg.conf.nvidia-xconfig-original empty?
  • why does xorg.conf.failsafe lists vesa as driver?
chanHXC
  • 1,063
xorg.conf is the one that is being used, if available. It is no longer required, which is why the original was empty; normally, it's not even present, but certain install scripts, such as nvidia, will create backup copies when making a change.
So, the failsafe copy is one that will work, but at a reduced resolution and functionality. It may have been created by an old installer, as I don't think nvidia creates that. But I no longer have nvidia drivers, so I could be mistaken. If you run the nvidia script more than once, you'll end up with more backups.
If there is ever a problem with video, such as no GUI at all, you can often use a terminal to go into the directory and rename the files to change the behavior. In theory, you can rename xorg.conf to xorg.conf.1, or anything else you want, and then copy the failsafe version to xorg.conf.
There is some good information on askubuntu, such as this:
Marty Fried
  • 18,944
man xorg.conf will give you a lot of information in this sense:
NAME
   xorg.conf, xorg.conf.d - configuration files for Xorg X server
INTRODUCTION Xorg supports several mechanisms for supplying/obtaining configuration and run-time parameters: command line options, environment variables, the xorg.conf and xorg.conf.d configuration files, auto-detection, and fall‐ back defaults. When the same information is supplied in more than one way, the highest precedence mechanism is used. The list of mechanisms is ordered from highest precedence to lowest. Note that not all parameters can be supplied via all methods. The available command line options and environment variables (and some defaults) are described in the Xserver(1) and Xorg(1) manual pages. Most configuration file parameters, with their defaults, are described below. Driver and module specific configuration parameters are described in the relevant driver or module manual page.
xorg.conf.failsafe file is for the case in which you messed up something on your machine and you need to boot in failsafe mode. For this reason the use of the generic VESA video driver. Again, for more information you can call man vesa:
DESCRIPTION
       vesa  is  an Xorg driver for generic VESA video cards.  It can drive most
       VESA-compatible video cards, but only makes use  of  the  basic  standard
       VESA  core  that is common to these cards.  The driver supports depths 8,
       15 16 and 24.
And finally, for xorg.conf.nvidia-xconfig-original file, again you will find enough information in man pages. man nvidia-xconfig:
   --restore-original-backup
          Restore  a  backup of the X configuration that was made before any
          changes were made by nvidia-xconfig, if such a  backup  is  avail‐
          able. This type of backup is made by nvidia-xconfig before it mod‐
          ifies an X configuration file that it has not previously  touched;
          this  is  assumed  to be an X configuration file that predates the
          involvement of the NVIDIA X driver. As an example,  nvidia-xconfig
          will  copy  an  X  configuration  file  at  /etc/X11/xorg.conf  to
          /etc/X11/xorg.conf.nvidia-xconfig-original the first time it makes
          changes to that file.
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
