running Ubuntu 12.04 LS and it tells me that it can't complete install on linux-image-3.5.39 because of dependencies. running 'apt-get -f install' doesn't do anything. How can I remove anything from "/boot" . It doesn't let me install anything, so I got to work with the packages I got.
uname -r --> linux 28.
suggestions are very much appreaciated
installArchives() failed: (Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 291331 files and directories currently installed.)
Unpacking linux-image-3.5.0-39-generic (from .../linux-image-3.5.0-39-generic_3.5.0-39.60~precise1_amd64.deb) ...
Done.
dpkg: error processing /var/cache/apt/archives/linux-image-3.5.0-39-generic_3.5.0-39.60~precise1_amd64.deb (--unpack):
failed in write on buffer copy for backend dpkg-deb during `./boot/vmlinuz-3.5.0-39-generic': No space left on device
No apport report written because the error message indicates a disk full error
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 3.5.0-39-generic /boot/vmlinuz-3.5.0-39-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 3.5.0-39-generic /boot/vmlinuz-3.5.0-39-generic
Error in function:
SystemError: E:Sub-process /usr/bin/dpkg returned an error code (1)
Setting up initramfs-tools (0.99ubuntu13.1) ...
update-initramfs: deferring update (trigger activated)
dpkg: dependency problems prevent configuration of linux-image-generic-lts-quantal:
linux-image-generic-lts-quantal depends on linux-image-3.5.0-39-generic; however:
Package linux-image-3.5.0-39-generic is not installed.
dpkg: error processing linux-image-generic-lts-quantal (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-generic-lts-quantal:
linux-generic-lts-quantal depends on linux-image-generic-lts-quantal; however:
Package linux-image-generic-lts-quantal is not configured yet.
dpkg: error processing linux-generic-lts-quantal (--configure):
Processing triggers for initramfs-tools ...
update-initramfs: Generating /boot/initrd.img-3.5.0-37-generic
gzip: stdout: No space left on device
cpio: write error: Broken pipe
E: mkinitramfs failure cpio 1 gzip 1
update-initramfs: failed for /boot/initrd.img-3.5.0-37-generic with 1.
dpkg: error processing initramfs-tools (--configure):
subprocess installed post-installation script returned error exit status 1
initramfs-tools
