How can I open python file (from desktop) with IDLE, using Terminal on Ubuntu 12.04?
I have tried to do this way:
$ idle open python_file.py
Instead of open my file it's create two more files: open and python_file.py.
It's just
idle python_file.py
If you want it to run in the background (returning control to the terminal so you can type other commands), add '&'
idle python_file.py &
If you want it to continue running even if you close the terminal you can 'disown' it
idle python_file.py & disown
You do not need to use the 'open' term. The help says:
idle.py [-c command] [-d] [-e] [-s] [-t title] [arg] ...
-c command run this command
-d enable debugger
-e edit mode; arguments are files to be edited
-s run $IDLESTARTUP or $PYTHONSTARTUP first
-t title set title of shell window
You can just do this:
idle file_you_want_to_open.py
or
idle.py file_you_want_to_open.py
If the file doesn't exist then it will be created.
You can also directly open idle by typing :
idle
in the terminal and then click on
File >> New File or Open File
option to select or open your file , write your program and execute it . However I would recommend you to use the "terminal" and a "text editor" like
Sublime Text
rather than using "idle" .
PS: You might already know about these text editors , however I mentioned it in case somebody else new views this article and maybe it comes in handy .
If you want to get your command prompt back after executing idle you could use:
nohup idle /some/path/to/file.py &
or if the file is in your current directory:
$ ls
file.py
$ nohup idle file.py &
Of course the last one will work if you are in the current directory, if the file do not exist IDLE will create one.
To install and use latest idle,
Go to synaptic package manager and install idle-python3.2
Then go to terminal and just type
idle-python3.2
This will open idle-python3.2.
Installation location => idle-python3.2 in SPM->(select)->idle-python3.2->(right-click)->properties->Installed Files.
