22
I am trying to make a package of a piece of software that I've (co-) written. I'm using
debuild -i -us -uc -b
And in principle that works fine. In order to shorten compilation time I'd like to debuild to run make in parallel (like I normally do by running make -j4, for example). I've found a few locations on the web that suggest the following:
debuild -eDEB_BUILD_OPTIONS="parallel=4" -us -uc -b
debuild -j4 -us -uc -b
Another site suggested to add some code to the debian/rules file that basically sets
MAKEFLAGS += -j4
However, none of these seems to work. Have I missed something? or should I change something in the autoconf/automake settings of the source?
muru
  • 207,228
ph0t0nix
  • 1,397
It has to be enabled in debian/rules. If the package uses dh, there is a line like this in debian/rules:
dh $@
Change that to
dh $@ --parallel
Then your commands will work, at least DEB_BUILD_OPTIONS="parallel=4"
gggf
  • 216
11
I recommend using the DEB_BUILD_OPTIONS environment variable, as described in section 4.9.1 of the Debian Policy Manual.
DEB_BUILD_OPTIONS='parallel=4' debuild -i -us -uc -b
Spooky
  • 109
Manuel
  • 211
10
With debhelper 10, you no longer need to supply the --parallel option in debian/rules; it now runs parallel builds by default. See the release notes
The answer, is therefore, just to set the contents of debian/compat to 10 and to update the debhelper version to >=10 in debian/control.
rbrito
  • 379
To sum-up all the above, that worked for me:
export DEB_BUILD_OPTIONS='parallel=16'
fakeroot debian/rules binary
midenok
  • 848
  • 15
