I've recently switched from Windows to Ubuntu since I was windows 7 made my laptop very slow.
I thought updating Ubuntu before I start using it properly would be the best option, but when I start updating, I cannot browse the internet anymore.
The same happens when I'm downloading a torrent or installing an application from Ubuntu s Software Center.
Is there any way to fix this? I experienced same issue in Linux Mint 15 as well. Haven't had this issue in Windows though.
Can somebody help me understand why it happens in Linux?
Alvar
  • 17,038
Uma
Maybe this is because downloading torrents/packages uses all of your download bandwidth. You can try to investigate this by limiting the download/upload speed in yout bittorrent client. In the Transmission client you can find this in the menus via Edit -> Preferences -> Speed.
See the answer to This question for information on how to throttle the bandwidth usage of apt, the package manangement software.
ph0t0nix
  • 1,397
In most of the times it is not Operating System's error, it is the torrent client that saturates your connection.
I have faced many times this problem on Linux machines and with various clients Transmission, Deluge, etc.
The solution is to optimize your client according to your connection. There is a guide I always follow when I setup a new system.
Check the following, they are from the same website:
I take it that your internet connection is not very fast and this causes problems not only with Torrent clients but while apt is running for updates/upgrades and installs. If this is the case you can check this answer on how to throtle apt-get download speed.
Stef K
  • 4,886
