I have Ubuntu 13.04 Server on a Virtual Box which is using 2GB of ram and 20GB of space. It's freshly installed and I cannot use apt-get update.
I have tried the same on an Ubuntu 12.10 Server but it still doesn't work.
Every time I type apt-get update I get
0% [Connecting to ca.archive.ubuntu.com (91.189.92.202)] [Connecting to security.ubuntu.com (91.189.91.15)]
Which then hangs for about 20 minutes, and then this displays
Err http://security.ubuntu.com raring-security Release.gpg
  Cannot initiate the connection to security.ubuntu.com:80 (2001:67c:1360:8c01::1a). - connect (101: Network is unreachable) [IP: 2001:67c:1360:8c01::1a 80]
Err http://ca.archive.ubuntu.com raring Release.gpg
  Cannot initiate the connection to ca.archive.ubuntu.com:80 (2001:67c:1360:8c01::1a). - connect (101: Network is unreachable) [IP: 2001:67c:1360:8c01::1a 80]
Err http://ca.archive.ubuntu.com raring-updates Release.gpg
Err http://ca.archive.ubuntu.com raring-backports Release.gpg
Reading package lists... Done
W: Failed to fetch http://ca.archive.ubuntu.com/ubuntu/dists/raring/Release.gpg  Cannot initiate the connection to ca.archive.ubuntu.com:80 (2001:67c:1360:8c01::1a). - connect (101: Network is unreachable) [IP: 2001:67c:1360:8c01::1a 80]
W: Failed to fetch http://ca.archive.ubuntu.com/ubuntu/dists/raring-updates/Release.gpg  Cannot initiate the connection to ca.archive.ubuntu.com:80 (2001:67c:1360:8c01::1a). - connect (101: Network is unreachable) [IP: 2001:67c:1360:8c01::1a 80]
W: Failed to fetch http://ca.archive.ubuntu.com/ubuntu/dists/raring-backports/Release.gpg  Cannot initiate the connection to ca.archive.ubuntu.com:80 (2001:67c:1360:8c01::1a). - connect (101: Network is unreachable) [IP: 2001:67c:1360:8c01::1a 80]
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/raring-security/Release.gpg  Cannot initiate the connection to security.ubuntu.com:80 (2001:67c:1360:8c01::1a). - connect (101: Network is unreachable) [IP: 2001:67c:1360:8c01::1a 80]
W: Some index files failed to download. They have been ignored, or old ones used instead.
However I can ping the IP address and domain on the server, and I can access it on my Host machine browser
davidrockin@ubuntu:/etc/apt$ ping -c 2  ca.archive.ubuntu.com
PING ca.archive.ubuntu.com (91.189.91.13) 56(84) bytes of data.
64 bytes from ragana.canonical.com (91.189.91.13): icmp_req=1 ttl=49 time=42.0 ms
64 bytes from ragana.canonical.com (91.189.91.13): icmp_req=2 ttl=49 time=43.3 ms
--- ca.archive.ubuntu.com ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1001ms
rtt min/avg/max/mdev = 42.088/42.742/43.396/0.654 ms
davidrockin@ubuntu:/etc/apt$ ping -c 2 91.189.92.202
PING 91.189.92.202 (91.189.92.202) 56(84) bytes of data.
64 bytes from 91.189.92.202: icmp_req=1 ttl=49 time=101 ms
p64 bytes from 91.189.92.202: icmp_req=2 ttl=49 time=98.9 ms
--- 91.189.92.202 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1002ms
rtt min/avg/max/mdev = 98.976/100.335/101.695/1.395 ms
davidrockin@ubuntu:/etc/apt$ ping -c 3 security.ubuntu.com
PING security.ubuntu.com (91.189.91.14) 56(84) bytes of data.
64 bytes from orobas.canonical.com (91.189.91.14): icmp_req=1 ttl=52 time=112 ms
64 bytes from orobas.canonical.com (91.189.91.14): icmp_req=2 ttl=52 time=44.5 ms
^C64 bytes from orobas.canonical.com (91.189.91.14): icmp_req=3 ttl=52 time=41.0 ms
--- security.ubuntu.com ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2003ms
rtt min/avg/max/mdev = 41.038/66.103/112.679/32.967 ms
I have tried modifying my /etc/apt/sources.list file to use a different respository
This is my current /etc/apt/sources.list file, which is the original file that was created when Ubuntu Installed.
deb http://ca.archive.ubuntu.com/ubuntu/ raring main restricted
deb-src http://ca.archive.ubuntu.com/ubuntu/ raring main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://ca.archive.ubuntu.com/ubuntu/ raring-updates main restricted
deb-src http://ca.archive.ubuntu.com/ubuntu/ raring-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
deb http://ca.archive.ubuntu.com/ubuntu/ raring universe
deb-src http://ca.archive.ubuntu.com/ubuntu/ raring universe
deb http://ca.archive.ubuntu.com/ubuntu/ raring-updates universe
deb-src http://ca.archive.ubuntu.com/ubuntu/ raring-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://ca.archive.ubuntu.com/ubuntu/ raring multiverse
deb-src http://ca.archive.ubuntu.com/ubuntu/ raring multiverse
deb http://ca.archive.ubuntu.com/ubuntu/ raring-updates multiverse
deb-src http://ca.archive.ubuntu.com/ubuntu/ raring-updates multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
deb http://ca.archive.ubuntu.com/ubuntu/ raring-backports main restricted universe multiverse
deb-src http://ca.archive.ubuntu.com/ubuntu/ raring-backports main restricted universe multiverse
deb http://security.ubuntu.com/ubuntu raring-security main restricted
deb-src http://security.ubuntu.com/ubuntu raring-security main restricted
deb http://security.ubuntu.com/ubuntu raring-security universe
deb-src http://security.ubuntu.com/ubuntu raring-security universe
deb http://security.ubuntu.com/ubuntu raring-security multiverse
deb-src http://security.ubuntu.com/ubuntu raring-security multiverse
I have tried restarting my computer, reinstalling my Virtual Machine, restarting my router many times, modifying the sources.list, and I have been googling for several hours, and can't figure out why it's not working.
I have also attempted to disable IPv6 (http://www.bearfruit.org/2013/05/06/ubuntu-server-having-ipv6-probs-its-easy-to-disable/)
Last night I had setup an Ubuntu Server to test it out, and apt-get update worked last night. Now, it's not working anymore on a new Virtual Machine. The one I created yesterday was deleted, and the new one I created today is not working.
My host machine is a laptop and I am using wifi, the specs of it is
Windows 7
8GB Ram
658 GB HDD (214 GB used)
AMD A8-3520M APU
Edit: I am not behind a proxy/vpn, and my internet connection is fine.
5 Answers5
Realizing I am stupid, it had nothing to do with the repositories or the Virtual Machine configuration.
All I had to do, was disable firewall on avast. Something I completely forgot about.
Looks like it is using ipv6 to apt-get and ipv4 to ping. It might be worth a try to disable ipv6 with a kernel parameter though I haven't needed to do this in a long time myself. In /etc/default/grub add ipv6.disable=1 to GRUB_CMDLINE_LINUX_DEFAULT=... then sudo update-grub
grantbow
  • 838
For future reference, I had this problem because we have a corporate proxy and I was using sudo:
sudo apt-get update
but the http_proxy env var got left behind... Switching to:
sudo -E apt-get update
got everything rolling again.
Lucas
  • 111
Case 1: the problem in terminal try to use main root terminal, Linux has two terminals ,try to use root terminals
$ sudo passwd root
[sudo] password for ramesh:
Enter new UNIX password:
Retype new UNIX password:
passwd: password updated successfully
this for root setup ,
Case 2: to install sudo pack properly ,if sudo commands are not working
type this in terminal
tar -xzf archive.tar.gz
or this
tar -xzf archive-name.tar.gz
cd archive-name
./configure
make
sudo make install
case 3 : if the above commands are not working try to use these commands
to check whats wrong in the terminal
auto-apt run <command_string>
or
apt-get check
or
dpkg-reconfigure fontconfig-config
Braiam
  • 69,112
If you are trying to connect from behind the proxy server, then ensure the correct proxy setting are done at
vi /etc/apt/apt.conf
Acquire::http::Proxy "http_colon//proxyserverip:proxyport";
then try
apt-get update
This should see you through the issue.
chaos
  • 28,186
