I can't understand why, when I tried plug-in external USB driver in Ubuntu 12.04, I see next message:
Error mounting: mount exited with exit code 1: helper failed with:
mount: only root can mount /dev/sdb1 on /media/sdb1
Here is content of /etc/fstab:
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
proc /proc proc nodev,noexec,nosuid 0 0
# / was on /dev/sda1 during installation
UUID=5f5d330f-d5f2-4157-9496-94f1dce2f181 / ext4 errors=remount-ro 0 1
# swap was on /dev/sda5 during installation
UUID=84747ef4-6f50-49bc-9df1-fcba364ba299 none swap sw 0 0
/dev/fd0 /media/floppy0 auto rw,user,noauto,exec,utf8 0 0
/dev/sdc1 /media/sdc1 vfat uid=1000,noauto 0 0
/dev/sdd1 /media/sdd1 vfat uid=1000,noauto 0 0
/dev/sdb1 /media/sdb1 vfat uid=1000,noauto 0 0
And this is my current sudo fdisk -l:
Disk /dev/sda: 160.0 GB, 160041885696 bytes
255 heads, 63 sectors/track, 19457 cylinders, total 312581808 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x000e28b8
Device Boot Start End Blocks Id System
/dev/sda1 * 2048 310484991 155241472 83 Linux
/dev/sda2 310487038 312580095 1046529 5 Extended
/dev/sda5 310487040 312580095 1046528 82 Linux swap / Solaris
Disk /dev/sdb: 993 MB, 993001472 bytes
2 heads, 1 sectors/track, 969728 cylinders, total 1939456 sectors
Disk identifier: 0x00000000
/dev/sdb1 133 1939455 969661+ 6 FAT16
Disk /dev/sdc: 4009 MB, 4009754624 bytes
16 heads, 32 sectors/track, 15296 cylinders, total 7831552 sectors
Disk identifier: 0xd8e1f237
/dev/sdc1 * 32 7831551 3915760 b W95 FAT32
sdc and sdb - there are external usb drivers.
Can I solve this trouble and mount all external usb drives automatically?
