After upgrade I can't log in. Error message:
Could not update ICEauthority file /home/username/.ICEauthority
This is on a system with 2 partitions. This installation is on /dev/sda5 type ext4.
Could this partition be read only? Maybe because of an error?
If so, how can I repair this partition?
BTW, I can login as guest.
Help highly appreciated...
Update User login works if I use recovery mode. Also, the partition is shown as read only. I can change this using the recovery console, but it looks like it changes back to read only if I'm returning to normal boot process out of the console. I tried to repair the partition with sudo rack.ext4 -v -f /dev/sda5 ( a command I found somewhere, without really knowing what I'm doing) but the results didn't show an error. –
