I have updated to Ubuntu 13.04 and now I can't run virtual-box I have installed dkms many times please help the problem shown is
Result Code:
NS_ERROR_FAILURE (0x80004005)
Component:
Machine
Interface:
IMachine {22781af3-1c96-4126-9edf-67a020e0e858}
Use 'apt-get autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 182 not upgraded.
N: Ignoring file 'virtualbox.li' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
I think it might be an underlining issue when I updated. I Tried googling it.
Braiam
  • 69,112
Virtual Box does not need DKMS to install but with DKMS the kernel modules will be reinstalled after a kernel upgrade.
After a fresh install it is always a good idea to perform an update of all packages for bugfixes (you have 182 package in the queue there):
sudo apt-get update && sudo apt-get dist-upgrade
Then you may have to load the virtualbox kernel modules only if you had removed DKMS from the default installation.
If this did not resolve your issue you may have installed an incompatible version of Virtual Box still. This needs to be purged before we can install an up to date version. Removing Virtual Box depends very much on how you had installed it in the first place. You may have to run e.g.
sudo apt-get purge virtualbox
or
sudo apt-get purge virtualbox-<xxx> # replace <xxx> with the version installed
After that we can re-install the latest version of virtualbox as depicted in the answer below (I recommend the latest bugfix release from Oracle rather than the version from the repositories):
Takkat
  • 144,580
First of all, you have to remove wrong repository:
sudo rm /etc/apt/sources.list.d/virtualbox.li
Then, upgrade your system
sudo apt-get update
sudo apt-get upgrade
rpadovani
  • 1,170
sudo apt-get update
Run these commands for update your OS.
The fololowings for install dkms and set for vboxdrv:
sudo apt-get install dkms
sudo /etc/init.d/vboxdrv setup
ubuntu_tr
  • 665
Adding to Takkat answer, you have a malformed file name in your /etc/souces.list.d. The best way to solve this is not deleting the file, but renaming it:
sudo mv /etc/apt/sources.list.d/virtualbox.li /etc/apt/sources.list.d/virtualbox.list
sudo apt-get update
This will take away the N: Ignoring file 'virtualbox.li' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension line, and also will upgrade your 183 packages.
Braiam
  • 69,112
