I have a problem with this code in terminal:
sudo apt-get install gnome-shell
It's not working
Look at this error
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
What should i do to install gnome3?
Thank you for that link.
I typed this code in terminal:
sudo rm /var/lib/apt/lists/lock
And this:
sudo rm /var/cache/apt/archives/lock
And my previous problem has solved.
But when I type this in terminal again:
It's doesn't work again!
Look at this error:
Reading package lists... Done
Building dependency tree
gnome-shell is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 219 not upgraded.
How can I use gnome3 interface?
