So, after learning that in order to boot into Ubuntu from a usb drive, I had to go into my bios and change the boot setting from UEFI to Legacy, I managed to install Ubuntu 13.04. Now, when I restart my laptop, it pops up the GRUB menu thing, and I can load Ubuntu no problem. But if I try to select Windows, I get an error saying windows can't be booted, and I need the recovery disc to repair this. but, since I don't have one, I thought it'd be a good idea to look around the boot settings again. Changing the boot settings from Legacy back to UEFI lets me boot into windows normally, but there is no option to get into Ubuntu unless I change it back to Legacy, which locks me out of Windows again. My question is, how can I make these options bot available to me without having to mash f2 to get into the bios every time I want to change my OS? Thank you in advance.
Bryce
Although the symptoms are slightly different, the solution I offered to this question is likely to work for you.
Rod Smith
  • 45,120
  • 66
  • 108
I have Ubuntu 12.04 running alongside windows 8.1 with no problems. I created the Ubuntu USB boot pen then, from within windows, I clicked restart while holding down shift. This presents different troubleshooting options. I selected boot from USB pen and the machine rebooted from the USB pen. In the BIOS settings (OK UEFI settings, I can't help saying BIOS as a generic term) boot mode was set to UEFI. As stated above, you can't mix the boot modes between operating systems. Hope this helps.
hatterman
  • 2,330
-1
try using these recovery disks
alternatively you can use EasyBCD (Easy Boot Configuration Data) and chain load grub. This guide shows you how to use it.
Akisame
  • 3,343
