I have Windows vista 64 bit with a free D: drive that has nothing on it.
How do I install Ubuntu Dual Boot
The drive is formatted but did I do it right? How can I tell?
You should install your Windows Vista. Next you should run Ubuntu form disc or pendrive and just install it. During the installation you will have check box "Instal next to Windows Vista".
And that is pretty all you need to do :)
Lucio
  • 19,191
  • 32
  • 112
  • 191
I didn't quite understand what is the exact problem you are facing while installing. Using the Windows installer is probably the easiest way to install Ubuntu alongside Windows. You can get started with the instructions given here. It will only work with 12.04 though.
