I want to copy any file to my external hard drive. But always when I tried to do this I have next output:
cp: cannot create regular file /media/NameOfCard/[file]' : Read only file system
I also tried:
sudo chmod -R 775 /media/NameOfCard
sudo chmod -R 777 /media/NameOfCard
But the same effect - ... Read only file system
Update:
After mount I have next output:
nazar_art@nazar-desctop:~$ mount
/dev/sda1 on / type ext4 (rw,errors=remount-ro)
proc on /proc type proc (rw,noexec,nosuid,nodev)
sysfs on /sys type sysfs (rw,noexec,nosuid,nodev)
none on /sys/fs/fuse/connections type fusectl (rw)
none on /sys/kernel/debug type debugfs (rw)
none on /sys/kernel/security type securityfs (rw)
udev on /dev type devtmpfs (rw,mode=0755)
devpts on /dev/pts type devpts (rw,noexec,nosuid,gid=5,mode=0620)
tmpfs on /run type tmpfs (rw,noexec,nosuid,size=10%,mode=0755)
none on /run/lock type tmpfs (rw,noexec,nosuid,nodev,size=5242880)
none on /run/shm type tmpfs (rw,nosuid,nodev)
/dev/sdb1 on /media/sdb1 type vfat (rw)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,noexec,nosuid,nodev)
gvfs-fuse-daemon on /home/nazar_art/.gvfs type fuse.gvfs-fuse-daemon (rw,nosuid,nodev,user=nazar_art)
Any suggestions?
  • How to solve this trouble and let permission to copy and delete files to hard drive?
catch32
  • 1,286
  • 32
  • 43
Also try this Open nautilus file manager as root by typing following command in terminal
sudo -i
Now enter your password
Now open nautilus file manager by typing nautilts in the terminal
Now find your external hard disk on nautilus file manager and open properties of your external hard disk.
Now click permissions tab and change file access to read write.
muru
  • 207,228
Yuvaraj V
  • 1,806
Try this:
mount -o rw,remount /dev/<devicename> /path/of/device/mount/directory
Example:
mount -o rw,remount /dev/sdb1 /media
papseddy
  • 516
As the message says, it is the whole external disk file system that is mounted read-only.
Use the mount command in a terminal to check the status of the disk - e.g.
/dev/sdc1 on /media/davidp/PHOTOGRAPHS type vfat (rw,nosuid,nodev,uid=1001,gid=1001,shortname=mixed,dmask=0077,utf8=1,showexec,flush,uhelper=udisks2)
For my example the first indicator in () is rw, which means read-write. I am betting yours says ro.
If that is the case, then the next trick is to find out why. Is the device set to be read only (some media has a switch to set it read only)? Is the file system corrupt? Could be many things.
David Purdue
  • 2,517
used windows 10 disk management and resolved the external hard drive dilemma and now I can access my external hard drive with Ubuntu without problems
Jurgen
