I have done a silly things. Some days ago I install dolphin in my Ubuntu 12.04. After that I was in love with dolphin for having thumbnail preview of folder with images inside. So, I thought of setting dolphin as a default file manager. So from the following link I found a solution: How to run Dolphin instead of Nautilus?
I have not followed the whole artical. Just used the first code:
sudo mv /usr/bin/nautilus /usr/bin/natilus.back && sudo ln -s /usr/bin/dolphin /usr/bin/nautilus
It makes my default file manager as dolphin. When I click to home folder launcher it now opens with dolphin.
Now I want to revert to Nautilus. But I am not getting any way to go back. But I thought if I change the upper code it may revert. So, I changed it with:
sudo mv /usr/bin/nautilus /usr/bin/natilus.back && sudo ln -s /usr/bin/nautilus /usr/bin/dolphin
And after that nautilus is not working. If I click home folder it also not working. If I write gksu nautilus in terminal it also not working after giving password. The only way that is left to access file manager is using dolphin. So, please help me. I need a solution. I need to make everything like before.
Now when I try to access mounted drive from launcher. It says:
Failed to execute child process "/usr/share/applications/nautilus.desktop" (Permission denied).
Please help me as soon as possible.
If I understand correctly you want to revert back the changes, ok. Then just do:
sudo apt-get --reinstall install nautilus
Is impossible to revert the commands since you made two big mistakes, instead of following the answers you followed the question. Also you ran sudo mv /usr/bin/nautilus /usr/bin/natilus.back twice. The second one was totally unnecessary. If you wanted to revert it the correct command for both was:
sudo unlink /usr/bin/nautilus && sudo mv /usr/bin/nautilus.back /usr/bin/nautilus
Braiam
  • 69,112
Here is what you did - each piece of code explained:
You renamed the Nautilus program to "natilus.back". (You misspelled too unless you meant to call it natilus instead of nautilus.)
If that succeeded (which it did)...
Make a link called nautilus which will actually execute dolphin every time nautilus is called.
By executing this...
... I think you renamed your link over your backed up program - nautilus (now the link) over natilus.backup. So now the nautilus program is gone. (I will stand corrected as I am not totally sure about that.)
What you should have done to reverse this was remove the link...
sudo rm /usr/bin/nautilus
...and rename the backup you made to its original name.
sudo mv/usr/bin/natilus.back /usr/bin/nautilus
(Again, assuming you did actually name the backup natilus.back instead of nautilus.back)
To fix, still remove the link you no longer need...
...then remove and reinstall nautilus with apt-get.
sudo apt-get remove nautilus && sudo apt-get install nautilus
Hope that helps.
colboynik
  • 756
