Unless you specifically set one, your root account probably does not have a password - the assumption being that you would log in as someone else and use sudo.
The guest account probably cannot use sudo, as that would be all sorts of badness.
Can you download and boot from the System Rescue CD (http://www.sysresccd.org/)?
Before you boot, do df / to work out which partition your root file system is on. e.g.
$ df /
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda1 192114204 101260032 81088596 56% /
tells me I need to remember /dev/sda1. I am assuming for the moment you are not using logical volumes as that adds a few steps in the next bit.
Now boot from the system rescue CD - this will (eventually) take you to a root prompt.
Now mount the root file system:
# mount /dev/sda1 /mnt
There are two ways to go here...
Simple - edit /mnt/etc/shadow, and remove root's password, change:
root:!:15842:0:99999:7:::
to
root::15842:0:99999:7:::
(note the missing !)
After this you should be able to reboot to Ubuntu and log in as root without a password (remember to set a root password after you log in!).
Complicated - If that does not work - then go back to system rescue and remount your root partition. Then try these commands:
# chroot /mnt
# passwd root
That should change the root password. Reboot, and log in as root.
