I installed netflix-desktop on my system running Ubuntu 12.04, and the app simply wouldn't launch. I removed it with these instructions here. I also ran these commands to clear out any settings: rm -Rf ~/.wine-browser and rm -Rf ~/.netflix-desktop.
I tried to reinstall with the instructions here, but I received the following error message:
sudo apt-get install netflix-desktop
Reading package lists... Done
Building dependency tree
Package netflix-desktop is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
  wine-browser-installer
E: Package 'netflix-desktop' has no installation candidate
I also tried installing wine-browser-installer, and that didn't work. Any suggestions?
Try: sudo apt-get purge netflix-desktop && sudo apt-get autoremove && sudo apt-add-repository ppa:ehoover/compholio && sudo apt-get update && sudo apt-get install netflix-desktop
This should (in theory) purge the entire netflix-desktop package and, since it sounds like you removed the ppa as well, add it back and reinstall the package. Omit sudo apt-add-repository ppa:ehoover/compholio && sudo apt-get update && if you did not remove the ppa.
Instructions as per http://ubuntuforums.org/archive/index.php/t-2084592-p-2.html and http://www.itworld.com/software/358908/install-netflix-ubuntu-1304
I had the same error. I removed netflix-desktop and purged the ppa. However, I also had to remove the following two files from /etc/apt/sources.list.d/ehoover-compholio-precise.list and /etc/apt/sources.list.d/ehoover-compholio-precise.list.save.
I had to remove these two files before I could correctly add the ppa and install netflix-desktop again.
chaos
  • 28,186
