Here's the deal:
I'm trying to install Shairport for an Airplay server. I'm running the latest version of Lubuntu. I'm following these directions (meant for a RaspberryPi, but I don't see any reason why they shouldn't work for any linux system). After I download and compile Shairport, I'm supposed to run make (to build Shairport). However, it keeps returning this error:
make: *** [hairtunes] Error 1
I installed make, uninstalled it, reinstalled it, recompiled Shairport, and nothing works. Any ideas?
When I run make, here's the full text (pasting the text in here wasn't formatting right, so here's a screenshot): https://i.sstatic.net/BiLjr.png
Thanks for any help!
Zach
  • 18
The tutorial in your link said:
Shairport has several prerequisites that need to be installed first. This is a single instruction to install them all:
pi@raspberrypi ~ $ sudo apt-get install git libao-dev libssl-dev libcrypt-openssl-rsa-perl libio-socket-inet6-perl libwww-perl avahi-utils libmodule-build-perl
But the shairport INSTALL.md file says:
Debian/Ubuntu:
sudo apt-get install build-essential libssl-dev libcrypt-openssl-rsa-perl libao-dev libio-socket-inet6-perl libwww-perl avahi-utils pkg-config
So, you can try to install all dependencies for shairport with:
  • sudo apt-get install build-essential libssl-dev libcrypt-openssl-rsa-perl libao-dev libio-socket-inet6-perl libwww-perl avahi-utils pkg-config
Then you can compile shairport.
Roman Raguet
  • 9,613
